07-13-2011, 08:49 PM - 1 Like   #1
dgaies's Avatar
Almost made it to 1:1 with my DA*300 (and lots of tubes)
Well, I almost made it to 1:1 with my DA*300 and lots of tubes w/contacts (I'm guessing somewhere around 150mm).
This was more just to see if it would work as this certainly isn't the most practical combination to shoot with
07-13-2011, 08:54 PM   #2
Wild!
07-13-2011, 08:56 PM   #3
good sir, i applaud you.
07-13-2011, 08:58 PM   #4
Bob from Aus's Avatar
Is it bending in the middle? I am bit jealous you have so many auto tubes
07-13-2011, 09:11 PM   #5
that is beautiful
07-13-2011, 09:17 PM   #6
dgaies's Avatar
QuoteOriginally posted by Bob from Aus Quote
Yeah, I'm pretty sure there was a little flex in the middle. That's partially why the picture of the setup was just a quick snapshot as I was worried about leaving the K-5 hanging out on the end for too long.
Three of the tubes are 2x TCs (with contacts) and the glass knocked out. One of them has PZ-AF contacts which actually allows for pretty decent AF as well (see this thread). They each were about $20-40, depending on how cheap I could find the TC. The ones with contacts but not AF are generally the least expensive and the ones with the Pz-AF contacts are generally the most expensive.
The other three tubes are a set of 12/20/36mm tubes AT-23 type tubes.
07-13-2011, 09:24 PM   #7
Frogfish's Avatar
Cool ! I love my DA*300 and think it's great for pseudo macro - never imagined it could get to 1:1 !
07-13-2011, 09:29 PM   #8
yeatzee's Avatar
Maybe I should stick my tak 300mm F/4 on the end of my bellows + all of my extension tubes and take a picture.....though im not sure the bellows could handle all the weight!
07-13-2011, 09:30 PM   #9
dgaies's Avatar
QuoteOriginally posted by Frogfish Quote
Unfortunately I don't think I quite got to 1:1, but it was really close! I think the width of that frame was around 25mm, give or take
07-13-2011, 09:31 PM   #10
dgaies's Avatar
QuoteOriginally posted by yeatzee Quote
Well, I don't think the 6 back to back K-mount connections appreciated the weight of the K-5 hanging off the end either
07-13-2011, 09:37 PM   #11
yeatzee's Avatar
QuoteOriginally posted by dgaies Quote
no doubt!
07-13-2011, 09:42 PM   #12
Thanks dgaies for describing the setup. I have two TCs on order for that purpose, but I suppose I don't know how to get the glass out until they arrive. I spent a bit more and got the auto focus.
07-13-2011, 10:34 PM   #13
That is a sight for sore eyes.
07-14-2011, 03:34 AM   #14
dgaies's Avatar
It's not too hard (to get the glass out), at least on the 4 TC's that I removed the glass from so far. There is a retaining ring on the bottom side which is all that holds the glass elements (and spacers) inside the TC. There should be two very small slits 180 degrees apart on the ring. I'm sure there's a better tool for the job, but I just use a small screw driver on one of the two slits to turns the ring counter-clockwise. I've had no trouble getting them off pretty easily so far. Hopefully the ones you bought will similar and straight forward.
07-14-2011, 11:56 AM   #15
Blue's Avatar
I only have one tube with af contacts, but it does wonders for allowing the DA* 300mm to be used to close focus.
da*300, k-mount, lots, pentax lens, slr lens, tubes
Tamron 28-75mm f/2.8, Best $300 I ever spent (lots of pics) Edgar_in_Indy Pentax SLR Lens Discussion 144 04-22-2015 07:01 AM
Rant: Are automatic extension tubes really not made anymore? Capslock118 Troubleshooting and Beginner Help 54 02-09-2011 08:16 PM
43mm 1.9 - Made in Japan Vs. Made Wherever today? Quality Issues? PentaxForums-User Pentax SLR Lens Discussion 6 05-09-2010 01:49 PM
For Sale - Sold: Kiron made Vivitar 75-150mm f3.8 M42 Lens + Lots of filters for sale Youngster Sold Items 2 12-10-2008 07:34 AM
All times are GMT -7. The time now is 01:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
