07-16-2011, 08:44 PM - 1 Like   #16
RioRico's Avatar
OK, I've written this: https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/152178-draft-a...eap-macro.html
Your comments and cat-calls are welcome!
07-16-2011, 09:13 PM   #17
yeatzee's Avatar
bout time
07-16-2011, 09:43 PM   #18
RioRico's Avatar
QuoteOriginally posted by yeatzee Quote
bout time
Yeah, yeah...
Now I need to write the art's about filters (including IR and actinic light), and optical strap-ons, and manual-aperture lens variations, and lens-chopping, and, and Kirlian work, and why torturing images can be fun, etc. I'm only in it for the lulz.
07-17-2011, 04:12 AM   #19
It is crazy to say you need a tripod, flash or macro rails to shoot macro. I have managed using only the "cheap" techniques and almost all handheld and have got some quite decent shots. Yes the hit rate is probably lower, but in the digital age is that such a big deal?
07-17-2011, 10:28 AM   #20
yeatzee's Avatar
QuoteOriginally posted by jezza323 Quote
who said that?
I will however say that you do need a flash unless 1:1 is all you shoot and IQ is not a big concern for you.
07-17-2011, 10:41 AM   #21
I was referring to this post regarding the need for tripod/rails etc
QuoteOriginally posted by littledrawe Quote
does 1:2 without the 01f 2X converter and 1:1 w/ the converter and I like it. It is not an autofocus lens so some people don't like that but the argument comes up that you don't want autofocus for macro work so why does it matter. These are not hard to find and KEH usually has mounts if you buy one from somebody who used it on a different brand of camera.
The other thing you might want to consider if nobody else has mentioned it is your macro set-up. You need a tripod to keep things steady a good head for framing the shot and I also think you need some type of macro rails for small incremental movement forward and backward to get the area in focus you want to. It seems to me that the focal plane at 1:1 is very narrow and just trying to move the tripod can be frustrating. Some of your $200.00 you may want to put in some of these areas.
07-17-2011, 01:48 PM   #22
yeatzee's Avatar
Oh, I missed that post Yes he is misinformed. At 1:1 thats all overkill and unnecessary unless deep stacking is the plan.
07-17-2011, 01:55 PM   #23
Laurentiu Cristofor's Avatar
Here's the least expensive, available new:
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/149140-inexpen...acro-lens.html
07-17-2011, 03:55 PM   #24
littledrawe's Avatar
My post was suggesting things that the OP might need/want to help him/her be more successful at macro photography. I don't think I am misinformed at all. I have tried handheld macro shots with a "low hit rate" and have been disappointed when they didn't turn out the way I was expecting. So why not suggest some other things that may be helpful, I didn't say if you don't have these you can't do macro work.
07-17-2011, 04:09 PM   #25
I agree if the language is appropriately hedged like "you'll probably find focusing rails & tripod useful for higher magnifications, focus stacking, or repetitive work with a set-up system."
Perhaps explaining why like "at 1:1 magnification and f:4 the depth of field is only about 1/2 mm
so precise camera positioning is required."
07-17-2011, 04:49 PM   #26
yeatzee's Avatar
The way you worded it, using the word "need" multiple times, suggests the idea that you can't do proper macro work without the stuff listed.
07-17-2011, 10:22 PM   #27
QuoteOriginally posted by grimmy2016 Quote
close to 1:1 and hopefully under $200 or so
Consider whether you really need 1:1. Does 1:2 qualify as "close to 1:1"? If you don't genuinely need 1:1 (I don't), consider the Pentax K, M, or A 100mm f/4 (1:2). The A would probably fall in the ~$200 range, the K and M less.
k-mount, macro, macro lense, pentax lens, recommendations, slr lens
18-200+mm lens recommendations varian Pentax SLR Lens Discussion 6 11-03-2010 05:18 AM
Which Lense Next? Sigma 30mm f1.4 or DA*200 f2.8 68wSteve Pentax SLR Lens Discussion 12 10-11-2009 11:24 PM
Noob Question Difference Between a Lense That Does Macro & A True Macro Lense Christopher M.W.T Troubleshooting and Beginner Help 16 07-19-2009 12:20 AM
50-200 replacement - any recommendations ? simonkit Pentax SLR Lens Discussion 13 09-02-2007 08:23 AM
All times are GMT -7. The time now is 02:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
