Originally posted by maxwest As the slr versions came later i don't think ill find an older one than this (with my small budget atleast), so i'm very interested in making this lens EF mountable (i want to have other full frame options than an a7s)
EF as in Canon EF? The only way you are going to convert a J-9 in LTM or Contax/Kiev mount to EF is to make serious modifications to the lens body and figure out a way to operate the camera so that the mirror goes up and stays up.
Edit: Perhaps, not so. See note below.
I took another look at the OP's photos of his "converted" lens and realized that despite initial appearance, it does have a manual aperture. I will correct my previous post. The Soviets had been making M39(Zenit) cameras since the early 1950s so a J-9 in that mount for 1956 is not improbable. While the lens does have a manual aperture and 1.15m minimum focus distance, the body is dissimilar to photos of early LTM versions and has the wrong focus direction. It is fairly similar to my Contax/Kiev J-9 except that if my lens were cut down to the dimensions of the lens in the photo, I believe the rear element would extend almost a full centimeter past the mount flange.
I believe his lens was likely made for a Zenit camera. Edit: I have found photos on the Web of other lenses similar to the OP's. These are identified as Contax/Kiev mount cut down to size. Apparently there is adequate rear element clearance to allow for the conversion to M42 or M39(Zenit) making this one of the few (only?) rangefinder lens where this sort of conversion is possible.
Back to your project...
If yours is the LTM version, you will find that it has a complex focus helicoid with inner and outer faces. The two have different thread pitch with one to drive the optical block and the other the rangefinder coupling cam. There are disassembly instructions on the Web. For conversion to EF mount you will need to shorten the barrel 1.58cm. The Contax/Kiev version has a simple helicoid and only needs to be shortened 0.92cm.
