07-19-2011, 10:34 AM   #1
telly0050's Avatar
Hoods for prime lens?
a lot of the pentax primes don't offer a place for hoods, how you guys get around with it?
I had a 35mm f2.4 and want to add a hood to it.
I looked at ebay and there are some hoods designed specific for the pentax, are those good?
or is it better to use srew in hood?
Thanks.
07-19-2011, 10:40 AM   #2
The dedicated hoods are usually better than round hoods as they provide better corner shade. You'll see lots of clip-on plactic hoods for older lenses, and I'd grab them if you get the chance!
07-19-2011, 10:49 AM   #3
Docrwm's Avatar
There are a bunch of clip on 49mm hoods out there. Frankly, the 3-stage collapsible rubber hoods are my favorites because they can be varied on the lens, provide some shock absorption, and are cheap and easy to find.
07-19-2011, 11:15 AM   #4
telly0050's Avatar
adam:
thx, but can you find me an example of clip on hoods?
i put in "clip on hoods" on ebay and it returns me no result
docrwm:
3-stage seems like a good buy, does it screw in or it is just rubber stick on the lens?
07-19-2011, 11:18 AM   #5
JinDesu's Avatar
It's usually a screw in type hood.
I personally prefer the rubber hoods because when collapsed, I can easily put on and take off the lens cap. Also, it lets me put on a polarizing filter without having trouble rotating it.
07-19-2011, 11:27 AM   #6
Pentax clip on hoods are usually plastic, so their product names will most likely include "PH-". They're relatively hard to find, but I'm surprised to see that you're getting no results at all.
07-19-2011, 11:33 AM   #7
axl
axl's Avatar
Look at old style Nikon hoods, made of metal screw in. 52mm thread so you'd need step up ring. For your 35mm I'd get hood for 50/1.4 or 1.8 from Nikon. I used to have them and they are great...
Also you can screw in CPL and the hood on top of it. Rotate hood and you'll rotate the CPL..
07-19-2011, 11:34 AM   #8
Here's one: Lens Hood as PENTAX PH-SA49 35mm F2.4 AL FA 50mm F1.4 | eBay
07-19-2011, 11:44 AM   #9
telly0050's Avatar
thx adam and axl
i think i would go for a 3-stage first, since it is cheap and such.
if it doesn't work well for me i'll jump back to the ph- hood.
07-19-2011, 12:01 PM   #10
audiobomber's Avatar
QuoteOriginally posted by telly0050 Quote
Thanks.
Unless the Pentax hood is specifically listed as being for a particular lens, there's a good chance you won't be able to use it. I have the rectangular hood for the FA 50mm and the petal-shaped hood for the FA 35mm. Both lenses are 49mm filter size, but the hoods are not interchangeable.
I use and recommend a standard 49mm rubber collapsible hood. I like this hood because it's very compact and allows easy filter use, especially a CPL. The rubber hood may actually provide better coverage than the original FA 35mm hood, because it was designed for a 50mm film lens.
If you want to stay with Pentax, there's this one:
Pentax 49mm Round Rubber Lens Hood 34260 B&H Photo Video
Otherwise a generic hood will be fine and costs a little less:
RLH49 Adorama 49mm Rubber Lens Hood
07-19-2011, 12:03 PM   #11
QuoteOriginally posted by Docrwm Quote
I use them myself, though it's true that rectangular or petal shades can offer more complete shading.
07-19-2011, 12:03 PM   #12
thx adam and axl
3-stage hoods are made for zoom lenses, no point on a prime, just added bulk for nothing. If you have to use it in the mid position on your lens it will drive you crazy. I have a couple of these that are permanently parked.
07-19-2011, 12:12 PM   #13
Docrwm's Avatar
adam:
docrwm:
They are typically listed as Asahi or Pentax hoods, most are 49mm that I have seen, and they are rigid.
The 3-stage hoods are screw on mostly. They run $3-5 and are Chinese these days. Still a good deal and they can be adjusted unlike the others (except the built in hoods).
07-19-2011, 12:15 PM   #14
loco's Avatar
I got one of those rubber collapsible hoods and the rubber came apart from the ring after very limited use. I was not impressed. Mine was generic. I did like that you could use a cpl filter with it. Is the Pentax hood of better quality?
07-19-2011, 12:21 PM   #15
Docrwm's Avatar
QuoteOriginally posted by loco Quote
I've got 5 of them and they are decidedly different in quality. Some are thick and seem substantial and others thin. I do not complain for $3, the fact that filters are a breeze with them, that they store better than any other hood (with the obvious exception of built ins which I love), and I have found which supplier (for now) offers the better quality ones.
hood, hoods, k-mount, pentax, pentax lens, slr lens
Pentax lines it's Da* prime lens hoods with felt?? Loren E Pentax SLR Lens Discussion 26 03-08-2011 10:14 AM
Lens hoods.. when to use? VHDEL Pentax SLR Lens Discussion 6 12-16-2010 05:15 AM
Lens hoods? matsui255 Troubleshooting and Beginner Help 15 11-29-2010 06:43 AM
Do I need 2 lens hoods? lovemehate Pentax SLR Lens Discussion 24 10-16-2010 10:06 AM
lens hoods beer_nuts Pentax Camera and Field Accessories 4 06-21-2010 09:33 AM
All times are GMT -7. The time now is 04:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
