View Poll Results: f/2.8 + 1.4 TC =
3.5 1512.50%
4.0 9075.00%
4.5 97.50%
What are you talking about? 65.00%
Voters: 120. You may not vote on this poll
11-21-2007, 04:44 PM   #1
Buddha Jones's Avatar
f/2.8 + 1.4x TC =
Survey says?
11-21-2007, 05:08 PM   #2
Arpe's Avatar
It cuts out 1 stop of light. But you will still be able to set your lens to f2.8, but just not as much light will get through and the camera's auto exposure settings will adjust for the lesser light.
11-21-2007, 06:03 PM   #3
RBellavance's Avatar
I'm pretty sure that it effectively "eats" 1.4 stops of light. However, it is usually rounded to 1 stop for ease of calculation. The correct answer would be 4.5, IMHO.
11-21-2007, 06:24 PM   #4
jfdavis58's Avatar
Mathematically it's actually 4.595 (approx).
11-21-2007, 07:08 PM   #5
Mikhail's Avatar
F-stops in 1stop increacements :1.0, 1.4, 2.0, 2.8, 4.0, 5.6, 8.0, 11.0, 16.0, 22.0, 32.0, 45.0, 64.0 ......
are full stops. So correct answer would be F4 as a 1.4xTC cuts 1 stop of light.
Thanks
"standard f-stop scale that corresponds to the sequence of the powers of "
11-21-2007, 07:12 PM   #6
mattdm's Avatar
I'm pretty sure 1.4× is used precisely because it approximates √2, which is the ratio between successive full F stops (rounded by convention). Which would make it f/4. A 2× teleconverter is conveniently back to integers since of course √2×√2=2, so that costs two stops.
11-21-2007, 07:18 PM   #7
QuoteOriginally posted by jfdavis58 Quote
What math are you using? 2.8 x 1.4 = 3.92 (~4) By that math a 2x TC would drop me back to f/5.6.
11-21-2007, 07:18 PM   #8
Mikhail's Avatar
QuoteOriginally posted by mattdm Quote
What he said!
Thanks
11-21-2007, 07:21 PM   #9
Mikhail's Avatar
Well its actually √2 x F2.8, and √2*2 x F2.8 = F5.6 is the correct way to do it, but they made the numbers work out nice and easily because not everyone is good at math!
Thanks
11-21-2007, 07:26 PM   #10
mattdm's Avatar
Okay, I give up. How are you calculating that value?
11-21-2007, 07:43 PM   #11
Ole
Ole's Avatar
a: aperture
D: Effective diameter of lens opening
f: focal length
a = f / D - that's the definition of aperture
You have in your example a = 2.8:
2.8 = f / D -- we will use this ratio below.
Now you add the 1.4x converter, so the new focal length f' = 1.4 x f
The new aperture
a' = f' / D = (1.4 x f) / D = 1.4 x (f / D) = 1.4 x 2.8 = 3.92 ~= 4
11-21-2007, 07:44 PM   #12
I be the one not good at math.
11-21-2007, 09:53 PM   #13
Eaglerapids's Avatar
I'm getting a headache:-).
11-21-2007, 09:56 PM   #14
OK, I am going to go with 4.
11-22-2007, 07:39 AM   #15
Nice thread, cleared that up for me !
k-mount, pentax lens, slr lens
All times are GMT -7. The time now is 11:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
