Originally posted by jezza323 In reviews on photozone the 10-17mm fared much worse in the CA test than the Samyang 8mm they tested (albeit on different cameras, which could explain the difference)
Photozone tests the thickness of the CA: thicker CAs are "worse." But the real issue is how easy or difficult it is to remove the CAs in post. I can't speak of the Samyang in this regard, but, in Lightroom at least, most of the CA issues with the DA 10-17 can be removed or severely mitigated. In other words, unless you're very uptight about CA, I wouldn't regard it as an important issue.
Another thing about photozone reviews: they tend to concentrate only on those aspects of a lens that can be measured. But there's far more to a lens than what can be measured. The DA 10-17 was supposedly designed by Jun Hirakawa, who is on record as stating he doesn't care about measurements; what's important, rather, is the uniqueness and beauty and piquancy of the final image produced by the lens. The Samyang may produce narrower CA and a bit more resolution than the DA 10-17, but does it produce better images? Not from what I've seen. The Samyang doesn't come close to producing the rich, vibrant colors or the excellent microcontrast of the DA 10-17. The Samyang also, from what I've heard, doesn't have the flare control of the Pentax lens -- but that's another feature photozone fails to test for.
