There are large differences between the three lenses that seem to be in play here - the 10-17, 12-24 and the 15, along with some of the other FE primes that are out there. Each lens has it's place and provides somewhat a specialized functionality.
As I wrote in another thread - I received an all expense paid 14 day luxury cruise to Hawaii, courtesy of the US Navy a couple of years ago (the Cruise ship was painted grey). Actually, I made the best of it and had a good time - as I was supporting a couple of new systems they were evaluating. Anyway, I had the opportunity to take a shot while we were performing an underway replenishment (UNREP), from on one of the flight elevators - about 30 feet out over open water, at sunset. One of my most favorite images I have taken.
The image to be effective really needed to be that wide, and stitching was not an option since everything was in motion. So the 180 degree wide shot is very effective. The 12-24 would have only covered - at best a but less than 2/3 of the shot in width.
CA on this lens has never been a problem, and this is a perfect opportunity for CA, a direct shot into the sun, through the lattice work of the mast.
The "narrower" end of the 10-17, although not as pronounced in terms of fisheye effect is still very useful, even though its limited to just 100 degrees of view. When you compare this to the DA 15 which is "only" 83 degrees wide you have a significant 17 degrees of difference between the two lenses. That's a difference of 20% over the 15mm lens.
Also, as an aside, I have tried to defish this as an interesting exercise. The result has the destroyer's stern and fantail, pulled out of proportion. Maybe it was just my eye, knowing what to expect, but it would up looking better just as it was taken with the fisheye distortion and all....
Originally posted by RioRico Just don't use the this at 10mm in an evergreen forest. All the trees are falling on me! HELP!!!
.... and Rico - Yes, you can see the mast of the BHR falling in on you!!
