I've been using the Sigma equivalent: a 18-50mm f2.8 EX DC MACRO for over a year
and always looking for sharper results @ f2.8 had tested a copy of the Tamron last winter,
not impressed with the bf/ff issues I returned it a few days later.
Since then discovered the now 'not-so-secret' K-x DEBUG_MODE trick and a couple of weeks ago
decided to give Tamron a 2nd chance while I sent my Sigma in for some warranty work.
I tested three copies of the Tamron 17-50mm f2.8 on the camera shop's counter
using a focus test chart until I found the one that worked the best with my K-x,
back home I still had to fine tune a bit of back-focus problems with the "DEBUG_MODE trick" to get it to focus perfectly.
I now like it so much that once my Sigma is back from repair its most likely
that it will become the spare lens and the Tamron will continu as my main lens.
If you find a 'good' copy, the Tamron is certainly a nice/sharp f2.8 zoom lens at
a decent price, but I would
only recommend it to anyone wanting to buy that :
1) you can test/exchange it until you find a 'good' one that matches your camera
2) have AF micro-adjustments available in your camera's functions
3) are willing to play in the DEBUG_MODE to fine tune if your camera doesn't have above#2
Michel
