Originally posted by thomasxie Hi, I did not mean to offend anybody by doing a small surgery on the lens. In fact, I will buy the "expensive" adapter if I am shooting with Pentax all the time. I am just exploring the possibilities.
I doubt many here are offended. Yes, I have adapted inexpensive C/Y lenses for Pentax. No screw removal needed -- I just used a Dremel tool to taper the lens bayonet flags slightly so they fit under Pentax mount lugs. I also cut a small slot in the lens base for the Pentax locking pin to engage, for a secure fit. This is 'minor' surgery that still allows the lenses to be used on C/Y mount cameras.
The Leitax lens-base-replacement is rather expensive. A decision on whether to choose Leitax, or to perform this minor surgery, probably depends on value and expectation. How much is the lens worth? Do I expect to ever sell it? Do I want a slightly-cut lens that will fit both PK and C/Y mounts, or a professionally-done job that can ONLY be used on Pentax? I can't make that decision for other people.
The C/Y base is very similar to OM, and the OM surgery is the same as for C/Y, except that I need to tape-down the lens' stop-down button. A bit of metal duct-repair tape works just fine; it is the same tape I apply to manual lens bases to enable Catch-In-Focus. Modifying Nikon AI-mount lenses is more invasive; I cut off the "nub-and-arc" protrusions from the aperture ring, so the lens cannot be used on Nikon cameras again. But with cheap lenses, I don't care!
My first C/Y mod was a planar Yashica ML 50/1.4. I am very happy with it. Have fun with your great lens on Pentax!
