I have been lucky and carefully acquiring a lens setup aimed at land & city scapes. 10-17 FE, 12-24, 16-45, Contax 28, 31 Ltd, A 50, and another Contax 85 - all for landscapes, and I stitch with all of them - even the 55-300. I have not acquired all of these at once - the 12-24 took me a bit over a year to save for.
The 10-17 is a wonderful lens. As others have written, the colors are wonderful. at 10mm its has a fisheye bend to it, and you can manipulate it to where you want it to be (slight tip up or down, while having a level horizon). At 17mm at times you are hard pressed to find the fisheye effect it all - depending upon the photo subject and composure. Its Angle of View is from 180 to 100 degrees. However, its still a specialty lens and it can be overused. There are some subjects that it does not do well on - man made square, rectangular and linear objects - architecture. Fisheyes tend to treat natural objects trees, mountains, etc. much better, however there are always exceptions.
It complements the 12-24 and 16-45 very well. The only way you can compare coverage between a rectilinear and fisheye is through Angle of View.
All of that said - if you are into land and city scapes, you will (or should be) interested in tripods and heads also - in particular something that will give you level panning for panoramas, especially at dusk and at night.
There are no ends to the opportunities for spending your money here in photography.....
hope that helps....
