07-27-2011, 02:37 PM   #1
telly0050's Avatar
Extreme slow focus with the DAL 55-300???
Got this lens with my k-x kit. This lens got a lot of good reviews, and I really want to love it but it is hard.
yes, optically the photos look very sharp and contrasty out of the camera, but the focus can be amazingly slow.
whenever i want to focus something on the 200+mm, the focus ring will turn all the way to the end and back again. it takes about 4-5 seconds to focus something far away, and sometimes it can't even focus right. this is absolutely no good.
i found one way to solve it which is first focus on the 55mm end, and then zoom to 300mm and focus again, that way the focus ring won't be turning back and forth.
so does anyone having the same problem? or am i just getting a back copy or something??
Thanks.
07-27-2011, 02:45 PM   #2
Ash
Community Manager
Ash's Avatar
Cameras are not the most intuitive of machines - they often don't spin the focus ring the right way when autofocusing. Around where the focus point is, the camera has a better chance of getting it right. So, the virtue of quick shift in the DA version comes into play, but for yourself you may have to pre-focus on something near your subject to get faster AF locking.
07-27-2011, 02:45 PM   #3
mattb123's Avatar
Mine is pretty slow too. I think it's just the nature of this beast. Good light helps, and focusing wider like you mentioned also helps. Are you using any filters? If there is light loss or you use a linear polarizer instead of circular that will make things worse in this respect.
07-27-2011, 02:49 PM   #4
telly0050's Avatar
under bright sunlight it haunts a lot too.
which my fd's nikon 55-200 never has such a problem.
of course i don't expect it to focus fast like a prime, but taking 4-5 sec to focus sth is just way too long....
if i were to capture a rare bird on the road, it'll be very likely flied away before the lens get to focus it.
07-27-2011, 03:12 PM   #5
boriscleto's Avatar
Are you using multi-point AF or center focus?
07-27-2011, 03:25 PM   #6
telly0050's Avatar
i am only using the center point focus
07-27-2011, 03:39 PM   #7
agsy's Avatar
I also find the 55-300 very frustrating sometimes. What I noticed that if I select the focus point right above the center focus, it does much better with less hunting. Many times I resort to auto 5 focus and it helps.
07-27-2011, 03:57 PM   #8
twitch's Avatar
QuoteOriginally posted by telly0050 Quote
I have a 55-300 and it's no where near this bad. So long as I give the AF a good chance by putting the point over something with some contrast it takes well under < 1 sec to lock. It rarely has to rack the focus. It also makes no difference I've noticed in AF speed whether I'm zoomed in or not.
I think something sounds no quite right with your copy.
07-27-2011, 04:38 PM   #9
telly0050's Avatar
agsy: thx for your advise!
it does seem focus a lot faster wit 5 pts auto
i'll bring it outside for a test when i get a chance.
twitch: yea tat's why i am suspect my lens is a bad copy, that's why i posted it here and ask for everyone's opinion.
07-27-2011, 04:43 PM   #10
agsy's Avatar
agsy: thx for your advise! it does seem focus a lot faster wit 5 pts auto i'll bring it outside for a test when i get a chance.
I'm glad it helped. When I shoot action especially (such as at a water skiing event recently), auto 5 is the way to go for me. Thanks to the awesome high ISO performance of the K-x, I can keep my shutter speed high enough with this lens.
07-27-2011, 04:43 PM   #11
Ash
Community Manager
Ash's Avatar
It certainly doesn't take 5sec to focus on my copy, And it's not often I'd miss a shot I want to get with the lens. But then I'm not using it in low light situations.
07-27-2011, 04:57 PM   #12
telly0050's Avatar
maybe i am exaggerating the time a bit
with enough light and contrast it does a pretty good job on focusing.
what is the problem is that when you hold up the camera and look into the viewfinder on 200mm+ focal length, and if the viewfinder shows totally out of focus, the AF will mess up (focus ring turning all the way to the end and forth, and maybe focus right at the end), under that situation, it really takes a long time to focus.
07-27-2011, 05:05 PM   #13
twitch's Avatar
OK that sounds a bit more plausible. My 55-300 is the one lens I use quickshift on a lot to avoid this problem. Do you have the DA L version (grey stripe on barrel, plastic mount) or the DA version (metal mount, green stripe on barrel)?
07-27-2011, 06:33 PM   #14
Ash
Community Manager
Ash's Avatar
As per title, DAL - hence quick shifting not an option for the OP. Nevertheless, prefocus on a similarly distanced target and then time your shot for quicker locking.
07-27-2011, 07:08 PM   #15
telly0050's Avatar
so sounds like there's no best way to solve the problem
does sigma or tamron 300mm telescope lens have the same problem? will they go faster?
focus, k-mount, lens, pentax lens, slr lens
Silver fa 100-300 ot the DAL 55-300? RickB52 Pentax SLR Lens Discussion 8 07-25-2011 09:53 PM
Best Hood for DAL 55-300 cas814 Pentax SLR Lens Discussion 11 03-11-2011 04:34 PM
Tripod collar for 55-300 DAL stumpsitter Pentax SLR Lens Discussion 3 02-07-2011 07:31 PM
Nature try to shot the moon with k-x and DAL 55-300 kraijeck Post Your Photos! 9 12-04-2009 06:27 AM
All times are GMT -7. The time now is 03:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
