07-29-2011, 12:13 PM   #1
Lens compatibility - Tamron 24mm on KX?
Hi there,
I just purchased the attached Tamron 24mm/f2.5 for my KX.
It's obviously a K-Mount so it should stick on the camera without a problem, but I'm a little confused as to "how" I can use it.
Is it a model of lens that supports aperture priority (Av mode)? Is my KX capable of using any kind of automated mode with this lens or am I limited to the normal manual (M mode) with stopped-down metering?
Thanks a bunch,
Noah
07-29-2011, 01:13 PM   #2
Full manual only, sorry.
07-29-2011, 01:26 PM   #3
So this is a standard manual Adaptall, i.e. gives me the basic functionality of stopped-down metering and absolutely no love for Aperture Priority?
For Aperture Priority I'd have to find one of those expensive "PK-A" adapters that go for $50-$100, right?
07-29-2011, 01:26 PM   #4
Otis Memorial Pentaxian
This lens with its standard K-mount adapter is very compatible with your camera, though not in Av mode. Your adapter emulates a Pentax-K or Pentax-M lens (no "A" contacts). As such you are limited to M mode with stop-down (green button) metering. There is a sticky on this site with detailed instructions, but the basics are:
  • Make sure aperture ring is "enabled" in your setup menu
  • Camera in M mode
  • Select desired aperture on lens
  • Trigger stop-down metering ("green button") to set the shutter speed
You can use Av mode, but all exposures as well as metering will be made with the lens wide open at its maximum aperture.
07-29-2011, 01:28 PM   #5
QuoteOriginally posted by kidblue Quote
That is correct, though FWIW, I own both adapter types and use the non-A most of the time and feel that the PK/A version is not worth the extra money.
07-29-2011, 01:33 PM   #6
I'm still confused about the "green button" - It does the same thing as the +/- button, right? That seems to meter as well, stopped-down, of course. I've set the "green button" to a depth-of-field preview.
07-29-2011, 01:34 PM   #7
I just took a close look at your lens and noticed that it the earlier Adaptall (as opposed to Adaptall-2) version of the 24/2.5 (model CW-24). As such, you can expect limited forward compatibility to the A-contact Adaptall-2 adapter. I don't even believe that it will fit your lens. To the best of my knowledge Tamron never made an Adaptall (first version) adapter for Pentax-A.
07-29-2011, 01:42 PM   #8
So I've got a good manual lens that can be expected to function as a basic K-mount. That's cool.
Is it sensical to use the +/- as my meter and reassign the green button to something else so they both don't do the same thing?
Did I just answer my own question?
Is it a good lens?
k-mount, kx, lens, mode, pentax lens, slr lens, tamron
For Sale - Sold: Tamron 10-24mm F3.5-4.5 Di-II LD Lens (EUR) garethwebber Sold Items 4 05-21-2011 03:20 AM
For Sale - Sold: Tamron 01B Adaptall 24mm f2.5 (no mount) AE lens (Worldwide) cheekygeek Sold Items 6 05-10-2011 12:32 PM
Compatibility issue with Tamron 28-75 ? kamui Pentax K-5 19 12-29-2010 11:14 AM
Tamron Lens Compatibility jmgacnik Pentax SLR Lens Discussion 2 07-04-2009 05:47 PM
All times are GMT -7. The time now is 06:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
