Originally posted by David&karen Hi everyone. I have been looking for a 'Superzoom' for Karens K7, ans since the Pentax 18-250 or the Tamron version of it is not available, what do you recommend? I need it to be new, with a warranty, otherwise anything that is AF goes! And thanks in advance!
David
The DA18-250mm/Tamron 18-250mm can be found quite regularly on the 2nd hand market. See PF Marketplace,
www.keh.com, and
www.adorama.com (Used equipment). When you by from Keh.com and adorama, you have a return policy.
You can also post a Wanted Item message at PF (
Wanted Items - PentaxForums.com).
The alternative is the newer Sigma 18-250mm OS HSM K-mount. It is currently listed at $475 at Adorama.com.
I have myself the K-7 and DA18-250mm. The combo works very well and the DA18-250mm is truly a sturdy lens. I purchased the DA18-250mm from Keh nearly 2 years ago and the lens has been faultless.
Hope that the info will help....
