Originally posted by dgaies Well in that case, the Tamron 70-200/2.8 is a very sharp lens; sharper than the Sigma 70-200/2.8 lenses from my experience.
There are actually two versions of the Sigma - an OS one and a non-OS one - which one did you try?
Originally posted by imtheguy I also owned the Tamron Pz MC4 1.4x but did enough tests to show that just cropping the 300mm shot gave me at least as good an IQ and the focusing suffers badly (slow or gives up if you don't help it manually as stated in above post).
+1. I have tried some TCs a couple of times and I never found them useful. It seems safer to just crop from an image taken without a TC.
Originally posted by stormtech Sigma 170-500 APO 5.6-6.3 - I must have a pretty good copy as I get pretty good results when I shoot it @450mm and F8 or F11.
If you're happy with this one, what do you expect from a new one? It's rather hard to get great optics in 500mm range for Pentax (the only lens available today is the Sigma 500/4.5@$5,000). Teleconverters are problematic, as they tend to accentuate CA. A 300/2.8 would cost more than your budget and it would be a heavy lens. And I'm not sure if the DA* 300/4 would be much better than your Sigma@450mm once you crop from it.
Really, if you want tele lenses, you should get a Canon camera - you then get access to great lenses like the 100-400L/4.5-5.6. You just need to double your budget to cover for a body, but it's really an accessory once you start looking at such equipment.
