Originally posted by les3547 Okay, I deleted my former post because I changed the answer twice. I just double-checked the K-7 and focus confirmation and catch-in-focus work, but you lose electronic aperture control (and AF of course).
If you look at the EXIF data, all f stops are recorded as f2.4, which is strange since the lens only opens to f2.8. Since stopping down also darkens the viewfinder, in low light you have to open the aperture to focus, and then stop down to the aperture at which you wish to shoot. I don't mind that much, maybe a little
. . . The camera metered through the Zeiss just fine, and exposed accurately in Av mode.
Afternoon Everyone,
I guess I should have written a complete response, however I really did not want to go off in the the weeds. About a month ago I was looking at a number of images I had taken between the Contax and 31 Ltd, and the shutter times of the Contax appeared to be much faster than those of the 31 Ltd. I posted here about the observation...
The thread produced a lot of interaction - 35 posts, and the conclusion that was arrived at was as follows:
- The 31 Ltd being a Pentax lens that communicates with the camera in Manual and AV modes indicates that its wide open aperture is f1.8
- For any of the all manual lens, the Pentax body will automatically default to f2.4 as the wide open aperture (Av and Manual modes), due to their inability to communicate with the body.
I'll leave it to everyone to read through the thread, however the bottom line is, the f2.4 default is somewhat of a red herring. The manual aperture is set (on the Contax), the body meters the shot, and the most important aspect of all is the image comes out just as intended.
My takeaway from all of this is that in the Av mode, the shutter times when compared to a Pentax lens (that communicates with the body), may look a bit off. This however does not affect the image in any way, since the body meters through the lens with the manual aperture set, the images comes out just perfect (but in the EXIF the aperture is recorded as f2.4 the default value, with the shutter time recorded as shot).
