Originally posted by sjwaldron Interesting comparison. Good job.
A few negative points from my perspective though:
- No Auto-focus...
Yes, that's nice to have, though I grew up with manual focus, so it isn't a big deal to me, or to other photographers with similar experience. Even when I owned several autofocus lenses I was always turning it off.
The real thing I was trying to see is if the Zeiss could produce image quality in the same league as the FA31. I thought it did.
Originally posted by sjwaldron - Where can the Zeiss be bought besides ebay? If you managed to land one for under $400, is that normal? I find lenses out of production difficult to compare to ones that are readily available new like the 31mm.
I don't know of anywhere else, but they are often for sale there, as is the Zeiss Jena 135. I think $385 might even be a bit high, but mine was mint too. Still, you are right if you are suggesting that availability would be limited if lots of Pentax users suddenly started buying the Zeiss.
Originally posted by sjwaldron - Needs a Pentax mount conversion and tools to do it like a soldering iron and special Japanese screwdrivers?
If you click on the Zeitax link I provided, you can see only a proper screwdriver is needed, and I myself used a normal Phillips. No soldering iron . . . just take off the old mount and put on the new one, takes 5 minutes when you know what you are doing.
Originally posted by sjwaldron I wonder just how close in sharpness and rendering something like the Pentax DA 40mm f2.8 Limited is to the 31 or Zeiss. I bet the 40mm is a better value than both in that regard.
It might be a value (though I prefer the Voigtlander 40), but a 40mm field of view is vastly different than 28 or 31mm . . . even the difference between 28 and 31mm was very noticeable. In fact, my reason for wanting the 28mm was to fill the gap between my 20mm and 40mm lenses. Here's three pictures I took this morning using the VL40, Zeiss 28, and the VL20:
Voigtlander 40mm:
Zeiss 28mm:
Voigtlander 20mm:
