Originally posted by RioRico Ah, then a Kx-able workaround would be: Tv mode with a fast shutter like 1/500, and ISO range set to 100-6400 or whatever. The camera should try to keep the aperture tight and ISO low unless light is low; then it should open the aperture as far as possible; THEN is should boost the ISO.
Tricky business. That's why I use my K20D for action instead of my K-x. I love TAv mode.
Most lenses are soft at max aperture, so they should be stopped down. Depending on the light, aperture may not move off of wide open unless you boost the minimum ISO. OTOH, sports shots are most interesting when the background is blurred, so a wide aperture is preferred. No wonder fast lenses are standard for sports shooting.
I tend to favour sharpness, so I would likely use Av mode and boost ISO to keep shutter speeds up. The good news, this game will likely be in good light, so ISO shouldn't be excessive.
Originally posted by RioRico So, study the manual and experiment with settings, to find what works best.
Good advice. Knowing the gear and the tradeoffs (e.g. soft wide open vs blurred background or ISO noise) will always lead to a better result than a set rule.
RioRico's advice about high speed continuous shooting is very important to capture the peak moment. One thing I would add, is not to use the Lens Correction feature with high-speed shooting. Your camera will bog down and stop after only two or three shots. I believe Highlight and Shadow compensation slow down processing, so I would also leave those off.
