08-14-2011, 01:18 PM   #1
[langtitle=el]lens for pentax K20D[/langtitle]
Γεια σας. θα ήθελα ένα φακό για πιο καθαρές και κρυστάλλινες φωτογραφίες. έχω την Κ20D με τον απλό φακό της των 18-55mm . θέλω να πάρω ένα φακό όχι πολύ ακριβό και να έχει και λίγο ζουμ παραπάνω από αυτό που έχω αλλά δεν με ενδιαφέρει και παρά πολύ το ζουμ. Ποιον μου προτείνετε
Sigma 18-125 χιλιοστών f/3.8-5.6 DC OS HSM Zoom Lens
Pentax SMC DA 18-135mm F/3.5-5.6 ED AL (IF) DC WR φακού
Sigma 17-70mm f/2.8-4 DC Macro OS HSM Zoom Lens
Sigma 18-250mm F/3.5-6.3 DC OS HSM Lens Zoom Autofocus
08-14-2011, 01:53 PM   #2
your kit lens is actually quite sharp. just stop down the aperture to about f/5.6-f/8 and make sure your shutter speed is fast enough to not get any motion blur.
if you're really in dire need of a sharper lens, you'll be better off looking at prime lenses
08-14-2011, 01:56 PM   #3
Coeurdechene's Avatar
The 17-70 has a good rep...
But with those zoom ranges there are a lot of tradeoffs...personally i don't like them... and would advise to look into the Tamron f2,8 family, wich is very well priced and has got great quality.
I own the 28-75 f2,8 and i find the zoom range very very usefull...it would sit a lot more on the camera if i was not addicted to my siggy 8-16.
You can look some samples of the tammy quality in the tamron threads, or serching the lens in Flickr.
08-14-2011, 02:18 PM   #4
hcc
hcc's Avatar
To add to the previous posts, it would be useful if you could clarify your needs.
You listed some zooms with focal lengths overlapping your 18-55mm.
A number of options includes:
- Go for an all-around lens like
Pentax DA18-250mm/Tamron18-250mm (2nd hand)
Sigma 18-250mm OS HSM
The former is very well regarded and cna be quite easily purchased from the PF Marketplace, Buy & Sell New & Used Cameras ? Canon, Nikon, Hasselblad, Leica & More - KEH.com or Digital cameras, all other cameras and everything photographic from Adorama Camera (Used equipment). The latter is more expensive and the OS is redundant with the camera SR.
Both lenses will not show a drastic improvement in IQ but the focal length range is awesome.
- Go for a series of prime lenses with outstanding IQ. Pentax has some outstanding lens series including:
+ the FA Ltd series
+ the DA Ltd pancake series
Any lens from one of these series will have a huge IQ enhancement compared to the kit lens.
Hope that the comment will assist....
08-14-2011, 03:20 PM   #5
Ash
Community Manager
Ash's Avatar
Know the limitations of your current kit, then decipher whether you need more than what your gear is capable of before thinking of upgrading. The kit lens is a very decent little lens, and very sharp at f/8.
08-14-2011, 04:09 PM   #6
twitch's Avatar
I'd suggest the DA 55-300 to be used along with your existing kit lens. The combination of these 2 will have better image quality than any of the single lenses you listed.
08-14-2011, 10:14 PM   #7
Marc Sabatella's Avatar
It would help if you posted some pictures you aren't happy with. Most likely, it's a matter of technique that would improve your pictures, not a new lens. To be sure, there are sharper lenses out there than the 18-55, but nothing on your list would make a noticeable difference. And really, even the sharpest lenses - none of which would be zooms with more range thant the 18-55 - would only show a noticeable difference when pixel peeping at 100%. You wouldn't be able to tell in a typical print or viewing normally on screen.
08-15-2011, 05:00 AM   #8
θα ηθελα ενα φακο για μεσα στο σπιτι να φωτογραφιζω την κορη μου και για τα ταξιδια αλλα με ενδιαφερει και το macro. οποτε τι λετε ?
08-24-2011, 11:20 AM   #9
για τον παρακάτω φακό τι λέτε?
Tamron AF XR 28-75mm f/2.8 lense
στα φόρουμ διάβασα οτι μερικοί φακοί
έχουν βγάλει πρόβλημα ξέρει κάποιος αν είναι αλήθεια?
δηλαδή αν τον έχει και έχει παρατηρήσει κάποιος κάποιο πρόβλημα γιατί με ενδιέφερε ο φακός.
για την χρήσει που τον θέλω έχετε να μου προτείνετε κάτι άλλο εκτός απο σταθερό γιατί θα ήθελα έστω και λίγο ζουμ.
θα προτιμούσα δηλαδή έναν φακό 17-70mm αλλά να έχει καλή ποιότητα στις φωτογραφίες από έναν 18-135mm όπου θα υστερούσε σε ποιότητα σε συγκρίσει με τον 17-70mm.
dc, hsm, k-mount, lens, lens for pentax, os, pentax, pentax lens, sigma, slr lens
Click Stops on Pentax 6x7 lens ? milarico Troubleshooting and Beginner Help 2 07-27-2011 10:10 AM
Macro Lens K-x Lost In big space. McDunk Troubleshooting and Beginner Help 6 04-27-2011 12:43 AM
K20D and K100DS Jakes Pentax DSLR Discussion 2 12-02-2010 12:39 PM
All times are GMT -7. The time now is 12:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
