Originally posted by Digitalis The foveon sensor in sigma cameras doesn't see colour the way people see it, the blues are less saturated than what you get with current bayer sensors. There is always in camera sharpening applied to the red channel, which suffers from a loss of acutance due to lateral diffusion which is caused by the type of silicon they use in the in foveon sensors .
so I would recommend the DA15mm f/4 and a decent Hoya circular polariser, and a few Grad ND filters.
The OP said he was using the Sigma 10-20 lens right? Not one of the cameras with a Foveon sensor? Interesting information though.
I'm yet another fan of the DA15 limited. I've used a polariser before on the DA15 and managed to mostly avoid the changes in gradient of the sky. I did this by being careful about how much 'polarising effect' I applied with the filter and also watched my angle to the sun.
However the DA15 seems to produce very saturated blue skies anyway, without a filter. Also note that the sky will naturally change in tone/gradient depending on where you are looking at it.
Here's the closest thing I could find to 'Alpen' shots with the DA15:
No polarising filter - note the change in sky tone to the right (closer to the sun)
No polarising filter - this is facing roughly in the other direction, with the sun over to my left.
