09-15-2006, 06:55 AM   #1
Buddha Jones's Avatar
Lens Filters
Does everybody use them? Should I get a UV lens filter and always use it? Any others?
09-15-2006, 07:05 AM   #2
Hi
QuoteOriginally posted by Buddha Jones Quote
Here is what I think:
- if you going to use one, get one that's good. no point putting a cheap (as in qaulity) piece of glass in front of a good expensive lens as it will degrade the qaulity of your photo
- some people use it to protect their lens but if you use lens hood all the time, then no need. However, if you are going to beach or other "risky" environment, yes put it on.
cheers
Kenny
09-15-2006, 08:04 AM   #3
That is exactly what I do: use one only in harsh conditions.
Toddlers with soiled fingers, that for some reason get attracted to the lens,
count as such elements:-)
With a really expensive lens (which I do not have, yet) I would buy a $80 filter thou.
09-15-2006, 12:31 PM   #4
Toshi's Avatar
I'd rather be safe than sorry so I use filters on mine. Got a Quantaray on my kit lens and a B+W on my Sigma; still need to pick one up for my 50mm. I don't see any difference in photo quality so I'll keep using them for now.
09-15-2006, 06:59 PM   #5
Hi Toshi
QuoteOriginally posted by toshifumi Quote
My personal experience is different. On a few occassions I have seen either reflection and/or flare by using cheap quality UV filters. For example, just this week when I was testing my newly-acquired 2nd-hand fa28/2.8 I found that I got flare problem if used with the cheap filter that I got when purchasing another lens. Took the filter off and took the same shot again, no flare! So now in the middle of getting a new filter for it.
cheers
Kenny
09-15-2006, 07:25 PM   #6
Ole
Ole's Avatar
Keeny, you may still get flare with a good filter unless you use a lens hood.
09-15-2006, 07:36 PM   #7
Hi Ole
I thought that might have something to do with it too. So I have ordered a hood for it from B&H about 3 days ago, hopefully will be receiving it, with other stuff, on Monday!! =)
Kenny
09-15-2006, 08:04 PM   #8
Toshi's Avatar
QuoteOriginally posted by kjao Quote
Hi Toshi
cheers
Kenny
Hi Kenny,
The Quantaray filter I have is about $20 and at certain angles when pointing in the general direction of the sun, I too noticed a little bit of flare, but nothing severe enough to make me want to take it off. As Ole pointed out, a hood helps out with that as well. On the other hand, the B+W filter was about $70 and you can really tell the difference in quality - it's top notch IMO
09-15-2006, 11:45 PM   #9
joele's Avatar
I used to use them for protection, but I don't anymore.. For one my lenses are insured and two well I have had no issue to date anyway... It just causes flare/ghosting and reduced contrast, why pay for those great SMC coated lenses and waste that coating by putting a lower grade coated piece of glass on top...
I admit do have a couple of different sizes of UV filters that I use in harsh environments like walking around on rocks at the beach (very windy lot of salt spray) but that is the only time I use them...
09-18-2006, 06:40 AM   #10
I'm slowly moving away from using them. I'd always used them, but I'm tending to use them more in harsher envionments now.
But I am finding that the polarizers seem to be on the lenses more now. Perhaps it's an inbred paranoia that something has the be on the end of the lens.
09-18-2006, 11:21 AM   #11
xfraser's Avatar
I use a UV filter on all my lenses, mostly for protection (but I'm a clutz and definitely need it!). I like to keep them on all the time, just so I have one less thing to remember. I try to get the best filter I can afford. I recently got a polarizing filter and it makes a big difference when I am photographing things that have reflections (cars, water). It gives you the option of getting rid of the reflection if you want to. I also use a lens hood on sunny days.
09-18-2006, 05:28 PM   #12
I have made a couple of "Home Tests". For the moment they are posted at DPR. I also have posted about my findings about UV-filters. Some of you have allready seen that post, some may not. I hope it helps somewhat:
http://forums.dpreview.com/forums/read.asp?forum=1036&message=19871654
I hope it can help somewhat.
regards,
Jonas
09-18-2006, 06:12 PM   #13
Ole
Ole's Avatar
Thanks Jonas for going through all that effort.
I'll now not even consider removing my filters!
09-29-2006, 10:05 PM   #14
Chilious's Avatar
When I bought my DA lenses (18-55mm and 50-20mm) which are 52mm threaded, I also bought a set of neutral density filters and a circular polarizer (and of course a UV filter). Then came the other lenses, with different thread sizes (49, 58, 60mm).
So, my question is the following: do you guys buy different filters for each thread size or do you use step-down/up rings? I presume that with a step-up ring there is no problem. How about step-down rings? Do they induce vigneting?
Any thoughts?
Robert
09-30-2006, 06:44 AM   #15
With UV filters I buy 1 for each lense. I have 2 sizes of CP and use step up rings to fit. I use a filter system for effects and mount to the lens with step up rings.
Step down rings don't work very well.
Dana
k-mount, lens, pentax lens, slr lens
For Sale - Sold: Filters OrenMc Sold Items 6 05-07-2010 08:17 AM
For Sale - Sold: Pentax Filters (for Collectors) Getting Old Sold Items 5 10-24-2009 03:00 PM
Help with closeup lens filters ctt Pentax SLR Lens Discussion 3 09-01-2008 05:39 PM
Close-Up lens filters Fl_Gulfer Pentax SLR Lens Discussion 14 05-10-2008 04:44 PM
All times are GMT -7. The time now is 04:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
