08-24-2011, 09:24 AM   #31
Marc Sabatella's Avatar
Any 135/2.8 or 200/4 has even thinner DOF but I don't recall many complaints about difficulty in nailing focus with such.
True, but with the narrow FOV, the shallow DOF doesn't have the same effect it does with a wider angle in terms of perception of softness - it becomes more obvious you are seeing shallow DOF rather than overall softness, because most likely, a great percentage of the actual picture area iss within the zone of acceptable sharpness. Also, the greater viewfinder magnification at longer focal lengths makes MF much easier.
08-27-2011, 07:17 AM   #32
QuoteOriginally posted by JHD Quote
And maybe my copy was just flat out atrocious - but I think not! It was fine at f2.8 and higher, but regardless of the light at f1.4 it was very soft which IMO is unacceptable... The evidence is all over the web and anyone can see for themselves , at f1.4 the Sigma 30mm is clearly in a different league from the FA50.
Hi guys thanks for all your post‘s, Do you guys think that Pentax will come out with a 1.4 30mm? or one closer to 50
I am seeing a lot of good posts about the Sigma 30mm, except the most of the treats start with the words " I seam to have gotten a good copy" !!!!
It seams that the quality may vary? what is you thinking about the Sigma lens, would it be a better buy.
Also I will be going to Bangkok in November, what do you think is a good street lens, I have the DA 40
and the 18-135 and also the DA 70. but the 18-135 is a bit big, and the 40 sometimes seames not wide enough, would a DA15 be a good choice, and is it good for portraits too, although one has to get a bit close to the subject.
Is DA15 a fast lens, or would I need a necessarily need a fast street lens?
thanks in advance
Silvan
08-27-2011, 09:48 AM   #33
paperbag846's Avatar
QuoteOriginally posted by gryphongryph Quote
You don't, but I would suggest that the 15 might be *too* wide for a street lens. The DA 21 might be better... not because it is faster, but its not nearly as wide... easier to work with and a great focal length for *hip shots*.
08-27-2011, 12:15 PM   #34
RioRico's Avatar
QuoteOriginally posted by paperbag846 Quote
Quite. I use my Tamron 10-24 for some street shooting, but at 24 rather than 10 or 15; and I use my Zenitar 16 indoors or in wide-open spaces, not on the street. The 10-16 range is great indoors; the 20-24 range is much better in tight streets. Wider streets demand longer lenses, so my 18-250 or the 21-24-28 primes get exercised there.
focus, k-mount, lens, pentax lens, slr lens
What's a FAST (used to be fast) film lens neverbnnba Pentax SLR Lens Discussion 11 07-03-2010 05:42 PM
How fast is the K7 really Jomy Pentax DSLR Discussion 12 11-16-2009 01:50 PM
Now that's FAST!! Wildnsyko General Talk 8 09-26-2009 07:32 AM
What is "Fast" about the fast Fifties... jess Pentax SLR Lens Discussion 11 01-04-2009 05:18 PM
A Fast Fifty Is Really A Fast 75mm drewdlephone Pentax SLR Lens Discussion 182 12-08-2008 10:38 AM
All times are GMT -7. The time now is 01:27 AM. | See also: NikonForums.com, part of our network of photo forums!
