08-22-2011, 04:46 PM   #1
lense foging up
Quick question, maybe someone might have a trick for me to overcome this.
When I walk outside from inside my house my lenses immediately fogs up, i know its beacuse of the temperture change especially being in Florida. Its sucks because if there is a pic i want to take lets say of two lizards fighting by the time my lense clears up the battle is over.
Thanks!!
08-22-2011, 05:04 PM   #2
REM
Being from Houston (similar weather) I understand. The best thing to do is usually wait a bit before you uncover the lens so it can normalize when walking into a different temperature zone.
08-22-2011, 05:31 PM   #3
thats what i fugured, thanks. its such a pita!
08-22-2011, 05:53 PM   #4
calsan's Avatar
The problem must be your air conditioning: - so going outside causes condensation on the cold dry lens..
Maybe try keeping your camera in an Esky or Igloo box (not sure what you call them there) - to prevent them from being cooled down by your A/C.
Another idea is that maybe a long cardboard lens hood could help by keeping a cushion of air next to the lens - like a dew shield used on amateur telescopes???
08-22-2011, 07:56 PM   #5
Wheatfield's Avatar
Unfortunately, there is no cure, the temperature of the equipment has to equalize, and that takes a bit of time.
Put the camera in a plastic bag before going out and let it warm up inside. Any condensation will form on the outside of the bag.
Or, can you arrange for your camera to have "outside air" for a while before you are going to go out?
08-23-2011, 01:04 AM   #6
Thanks guys, ill give them all a try!!
08-23-2011, 05:33 AM   #7
xjjohnno's Avatar
Turn off the aircon.
08-23-2011, 06:01 AM   #8
LaurenOE's Avatar
Also being from Florida - there is nothing you can do.
If I know I am going to be shooting outside in a few hours, I will place my gear (inside the backpack) out on the patio to let it get warm. Because the gear is inside something that is padded with foam, it will act as an insulator and let the heat in slowly.
Then, when my gear is up to the ambient temperature, it won't have problems going in and out of a cool car through the day as long as I put my gear back into the backpack and keep it zipped.
I suppose I should say that I use my camera backpacks as "thermal vestibules" because of the insulation properties of the protective foam.
It works the other way too when I am shooting in cold locations.
A backpack is a great way to prevent the "shocks" of temperature and prevent the radical condensation that can happen when moving in and out of temperature extremes.
k-mount, lense, pentax lens, slr lens
Which Lense Next ? Frogfish Pentax SLR Lens Discussion 7 04-17-2011 10:18 PM
lense sunnybrooke Troubleshooting and Beginner Help 6 11-01-2010 02:47 AM
best macro lense for a KX? dehanson1 Troubleshooting and Beginner Help 16 11-17-2009 03:28 PM
Which Lense for the K-7 SimoneDice Pentax DSLR Discussion 15 09-26-2009 03:44 AM
Noob Question Difference Between a Lense That Does Macro & A True Macro Lense Christopher M.W.T Troubleshooting and Beginner Help 16 07-19-2009 12:20 AM
All times are GMT -7. The time now is 02:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
