Veteran Member Join Date: Oct 2006 Location: Chicago suburb, IL, USA |
HI tabl10s,
I have a Tokina 80-200 f2.8 AT-X Pro AF2, It's the second AF model, and only differs from the AF1 in that it has a petal hood instead of a cone, IIRC. There might be some other differences, but I can't really remember. It was discontinued quite a while ago (3-4 years)
It's a very good lens, but not the best of the bunch, even in it's day. When it was current, the FA* 80-200 f2.8 was clearly the best, and also the biggest, heaviest, and most expensive, the Sigma EX 70-200 f2.8 APO (pre DG) was very good, and performed better than the Tokina optically, and was heavier and more expensive. IIRC, the Tokina was by a small margin the lightest of the 3, but had all metal construction, and it indeed is built like a tank.
Optically, the FA* was considered prime like, the Sigma was considered excellent, but not as good as the Pentax, and the Tokina was considered excellent, but not quite as good as the Sigma. Sigma later introduced the DG version of their zoom, and it was generally considered to be of lower optical quality than its predecessor, but I don't recall any comparisons with the Tokina, as it had already been discontinued. Way back when, the Pentax was going for @ $1500 USD used, the Sigma was $600-700 used, and the Tokina was @ $400 used. I chose the Tokina as I didn't plan on using this FL range that much (which has been the case), but wanted a fast zoom that covered the med to long tele range.
The Tokina has served me well, and when Sigma came out with their HSM version, and Tamron introduced their AF version in the same range, I wasn't even tempted to upgrade though each of these is a better performer than the Tok -- as I stated, I don't use this FL range that often -- I mostly shoot longer.
One more point about the handling of this lens. Tokina long zooms seem to torque more when auto focusing -- you can actually feel the lens want to twist in your hand. My Tokina 80-400 does the same, and these are really the only two lenses that I've felt this with.
Bottom line, it's still a pro caliber lens, though by a slight margin not the best in its class, but it's usually offered at prices that are hundreds of $$s lower than any of the alternatives (if you can find one). If you need fast, quiet focusing, the current Sigma HSM is better, both optically and in focusing performance, but TC use is a question mark (I know that PZ AF TCs will power the focusing motor, but I don't know about AF performance). If you want sharper, the current Tamron is considered the best (other than the FA*, and maybe the original Sigma APO) , and it's screw drive AF, so it can be used with any of the AF TCs. The Tamron is also the lightest of all the alternatives in this FL range, and is pretty reasonably priced.
I don't know if you're considering the MF 80-200 f2.8 lenses, but in case you are, the Tamron SP 80-200 f2.8 is clearly a sharper lens than the Tokina 80-200 f2.8 SD AT-X, but the Tamron is an Adaptall-2 lens and needs a PK/A adapter to be fully functional, and they've become pricey.
Scott
