08-25-2011, 06:27 PM   #1
35/2.4 hood
Will this hood work on the 35/2.4 without vignetting?
Thanks.
MLH49 Adorama 49mm Metal Lens Hood
08-25-2011, 06:41 PM   #2
That looks more like a hood for a 50mm, but I could be wrong.
08-25-2011, 07:21 PM   #3
Steinback's Avatar
It will probably work fine. I use similar metal hoods designed for a 50mm lens on a film body with my 28mm and 35mm lenses on digital bodies. I only run into problems when I forget to take the hood off and replace it with a shorter one the next time I use the lens with a film camera.
08-25-2011, 07:53 PM   #4
ramseybuckeye's Avatar
On the Pentax website it lists these compatible hoods:
Plastic Square-edged Spring Type (PH-SA49) Rubber Round Shaped Threaded Type (RH-RC49) Do a search and you'll find a lot of knockoffs, I've got a knockoff of the square one, works fine. You can possibly get the dimensions of the rubber and compare.
08-26-2011, 12:46 AM   #5
jremick's Avatar
I don't know the exact dimensions of the one you listed from Adorama, but I bought two on Amazon that look identical. Amazon.com: 49MM metal lens hood for Pentax & Takumar 35mm 50MM standard lens: Camera & Photo
I use them for my 35mm f2.4 and F 50mm f1.7 and they work great. I also bought two 58mm lens caps so I just leave the hoods screwed on and use the new lens caps when I put them away. The hoods are good quality, metal, and have ridges inside with a nice black finish to prevent reflections and is threaded for filters if you need (or to hold a lens cap nicely). The outside has a nice black finish as well that goes nicely with the 35mm f2.4.
Here's a couple quick snaps for ya. I'm mostly just happy that the lenses are better protected, but they also do a better job of keeping dust off the front.
08-26-2011, 04:29 AM   #6
I got these (but I do not know where to get them in the USA - maybe ebay...)
Klick-Gegenlichtblende Matin 49mm kaufen im Enjoyyourcamera.com Shop
It works great, the similar JJC product...how to say it... sucks (and I tried it)
@jremick
you got the same setup than I do lenswise
08-26-2011, 07:01 AM   #7
Thanks all for the replies, looks like it'll work.
08-26-2011, 02:38 PM   #8
QuoteOriginally posted by jremick Quote
Great idea with the lens caps
hood, k-mount, pentax lens, slr lens
Wanted - Acquired: PH-RBL 67mm hood & PH-RBH 77mm Hood stl09 Sold Items 0 02-14-2010 11:37 AM
Ft. Hood res3567 General Talk 238 11-10-2009 04:32 PM
For Sale - Sold: Pentax 18-55mm lens hood with box (no lens, just hood and box) drabina Sold Items 3 09-13-2008 06:21 PM
All times are GMT -7. The time now is 07:37 PM. | See also: NikonForums.com, part of our network of photo forums!
