Originally posted by jon_tan Hi, are you using the B+W "slim" type? I got one for my kit 18-55mmWR and the supplied lens hood cannot be mounted with the filter on. I changed to a normal profile one, the filter can be mounted. I guess the "slim" type filter ring may be slightly bigger towards the front end thus hoods with tight tolerance may not be able to mount.
Not exactly the issue. The hood on the 77mm isn't removable. So, mounting isn't an issue. However, since Franky pull the hood out with the filter mounted it would seem the outer diameter is blocking the hood.
FWIW, I've never put a filter on my 77mm, but just checked my Marumi CPL and it did not interfere with the hood.
