08-29-2011, 03:04 PM   #1
Help with repair Pentax A 35-105mm f3.5
I disassembled this lens and dont now how to put it together back. Has someone pictures that can help me with my problem.
08-29-2011, 08:54 PM   #2
Giveaway winner!
MysteryOnion's Avatar
How far apart? Glass out of barrel as well? Mount in pieces and the little tiny contact springs all over?
08-30-2011, 05:32 AM   #3
dadipentak's Avatar
Good luck with that--it's a very nice lens when assembled.
08-31-2011, 01:34 PM   #4
The bigest problem is the Mount.
08-31-2011, 03:02 PM   #5
Moderator PEG Judges
Kerrowdown's Avatar
If it's any consolation.....................................................
Once did this with a watch, which appeared to be sprung loaded and fired bits all over the place on the undoing of the last wee screw.
Good luck with the rebuild.
Oh the watch you ask, it never saw the light of day again.
08-31-2011, 06:30 PM   #6
Giveaway winner!
K-A mount you have a bunch of spring loaded contacts and a little grounded piece as well on some or all? That is the worst of the bunch and hopefully it is not lost. That piece will require some fancy positioning to get it to stay and while assembling the aperture ring. Have a look at the 50mm A 1.7...
Pentax Manuals
08-31-2011, 06:34 PM   #7
dadipentak's Avatar
QuoteOriginally posted by MysteryOnion Quote
That is the worst was the bunch
I can see why--it's a complicated lens.
08-31-2011, 06:39 PM   #8
Giveaway winner!
So if you have no missing parts, it is just a tricky slow process. If none of the guides and cams are disassembled from the element groups, just take your time and it should come together, try a little scotch tape to help grip parts from the outside of the mount while you work on the inside. ... sorry about the typo, doing too many things at the same time.
k-mount, pentax a 35-105mm, pentax lens, repair pentax, slr lens
pentax smc 35-105mm repair tr13 Pentax SLR Lens Discussion 20 01-09-2013 05:52 PM
K7 going into Pentax repair OrenMc Pentax DSLR Discussion 25 04-15-2010 01:19 PM
Help with Pentax repair in So. CA w6wat Pentax Film SLR Discussion 6 03-18-2010 01:48 PM
Pentax SF1 Repair TLcat Photographic Technique 2 12-19-2009 03:27 PM
All times are GMT -7. The time now is 07:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
