11-30-2007, 05:23 PM   #1
Thin filters really necessary?
I need to buy a circular polarizing filter for my 16-50 DA* lens. Do I need to get the thin version of the filter, or did Pentax take this into consideration when they gave it a 77MM size? I may also add the 12-14 lens to my bag sometime, also taking the 77mm filter. Same question for the 12-24, will I get vignetting if I use the standard thickness filter?
11-30-2007, 06:03 PM   #2
QuoteOriginally posted by Pentastic! Quote
I never had any problems with normal filters on my DA 16-45mm f4, so I wouldn't expect a problem with the DA* 16-50 f2.8. However, my DA 12-24mm f4 would vignette with a standard thickness filter from about 12mm to 14mm. From 14mm up it was fine, and it was also fine with a slim filter at 12mm. So if you want to use the filter on the DA 12-24mm at the wide end, get a slim filter.
11-30-2007, 11:28 PM   #3
Canada_Rockies's Avatar
QuoteOriginally posted by GaryML Quote
The standard thickness filters will vignette at the wider settings on the 12-24, as mentioned. I purchased, after thinking for a long while, a "Moose" Hoya circular polarizer (with 81A glass) to cut the high altitude blue down, as I do much shooting at up to 7,500 ft altitude. (I live at 3,800+ and hike.)
I reasoned that the sky is so uneven with a polarizer when the wide angle gets much past 28mm equivalent that I won't miss it at 12mm. Check with me after this summer ... I might be post processing a lot of vignetted images The ones with dark blue on the right and light blue on the left ...
12-01-2007, 09:28 AM   #4
Looks like I better make the additional investment in the slim filter.
Thanks for your help.
77mm, filter, k-mount, lens, pentax lens, slr lens
Thin Ice! (?) jsherman999 Post Your Photos! 4 11-16-2008 05:29 AM
Does DA 18-250 need "thin" filters bdphoto Pentax SLR Lens Discussion 0 08-29-2008 11:02 AM
I was standing on Thin Ice for this one little laker Post Your Photos! 31 12-03-2007 08:07 PM
thin CPs hll Pentax SLR Lens Discussion 1 11-16-2007 03:58 PM
All times are GMT -7. The time now is 07:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
