Quick (probably stupid) question of the day, do all Pentax lens ranges use the lever thing on the back of a lens to control the aperture of the photograph that's finally taken, or do any Pentax ranges close the diaphram drawing power from the contacts without needing the mechanical lever thing?
The way I think about that lever is like this - you set your f stop in camera, and when you take your shot, the information is sent to the lens about the stop you chose and a lever in the camera then pushes the lever on the lens which closes the diaphram and uses the f stop based on the info transmitted through the various electrical points. Is that more or less about right?
Bottom line, building one of these EOS retro reverse adapters for a Pentax is pretty trivial, but that's only true if there's no mechanical lever part to the equation. Just 2 parts of an extension tube with holes and a CAT5 cable connecting the points. But if that mechanical lever is required then I'm stuffed and it aint gonna happen
Cheers
