09-04-2011, 12:05 PM   #1
Lucky-Luc's Avatar
Pentax 50-200mm, vs Sigma 70-300 dg macro
I've done some test with those 2 lens.( they are both f4-5.6) At 200mm, the color are similar on both. but when I use the Sigma at 300mm, the color are faded.
Really desapointed, I think I gonna put a for sale sign on it.
09-04-2011, 03:36 PM   #2
If you want a cheap way to reach 300mm then choose the DA55-300. It won't disappoint. But I'm using the DA50-200 as well - small and light
09-04-2011, 03:51 PM   #3
SpecialK's Avatar
I found the Pentax was only very slightly sharper and had more contrast than the Sigma. The Pentax 55-300 is significantly better.
09-04-2011, 04:58 PM   #4
Philoslothical's Avatar
I haven't had that problem with my copy of the same lens. Is yours new enough that you can exchange it for another copy?
09-04-2011, 06:48 PM   #5
Lucky-Luc's Avatar
QuoteOriginally posted by Philoslothical Quote
No too bad, I've learn which store not to busness with anymore. Do you have the APO version ?
And SpecialK ,I should of bought the Pentax 55-300.
At the least I like my new Tamron SP AF 17-50mm f/2.8 xr
09-04-2011, 07:33 PM   #6
I don't have the APO version, no, just the 70-300 DG macro.
09-04-2011, 09:52 PM   #7
APO DG isn't likely to be much better at 300. I bought the APO DG version of the lens with my K10 years ago and can point out that the issue is likely with softness at 300mm at lower apertures. That said, at high apertures, the lens wakes up.
Have you tested the lens at high apertures? Perhaps f8-F11 or higher?
color, k-mount, pentax lens, sigma, slr lens
HELP! Sigma 70-300 f4-5.6 DG Macro OR Pentax DA 50-200mm f/4-5.6 ED AF tensai Pentax SLR Lens Discussion 2 08-08-2011 01:49 AM
Sigma 70-300 1:4-5.6 DL Macro vs Sigma 70-300mm F4-5.6 APO DG MACRO (Comparo) adr1an Pentax SLR Lens Discussion 7 05-08-2011 06:46 PM
Pentax DA 50-200mm vs Tamron/Sigma 70-300? SirJangly Pentax SLR Lens Discussion 11 09-06-2010 11:01 AM
All times are GMT -7. The time now is 06:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
