09-06-2011, 09:04 AM   #1
tomwil's Avatar
Is this Pentax Tamron 18-250mm repairable?
Saw this eBay auction for a Tamron 18-250mm lens, but seems to have the rubber zoom ring detaching. Is this user repairable, or acceptable as is? It almost appears like the lens was in extreme heat and the ring expanded.
09-06-2011, 09:17 AM   #2
blackcloudbrew's Avatar
I would say yes to that. I bought mine used several years ago and the rubber was loose. I sent it to Tamron for repair (which was still under warranty) and it came back just fine. I also asked them to tighten the zoom a bit as it really had a problem with lens creep. They did that too and I actually seldom need the lens lock set.
09-06-2011, 10:27 AM   #3
You should never include links to the auction. Your fellow Pentaxians might bid it out from under you or start a bidding war. good luck.
k-mount, lens, pentax lens, slr lens, tamron
Is the Pentax 18-250mm better than the Tamron? Muse Pentax SLR Lens Discussion 21 09-06-2010 06:49 AM
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
For Sale - Sold: Tamron 90mm, Tamron 18-250mm, Pentax AF-540 Flash jumbuc Sold Items 5 04-21-2010 12:49 PM
18-250mm - Pentax or Tamron cbaytan Pentax SLR Lens Discussion 58 01-13-2010 07:16 PM
All times are GMT -7. The time now is 06:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
