09-07-2011, 11:19 AM   #31
mikeSF's Avatar
QuoteOriginally posted by newarts Quote
Or don't put the camera in CIF (ie. AF.S) mode - just half-press & focus using the beep/green hexagon - then recompose & press the shutter all the way.
yes, this is how i normally use my MF lenses since the hexagon is functional, but the CIF idea would be useful to me only if there were a way to select a focus point (ie NOT in the very center). I dont often compose with the subject in the center, is all.
09-07-2011, 12:12 PM   #32
ManuH's Avatar
My 35s see much less use than my 28s and 50s on my K20D.
I find the 35mm an awkard FL (on APS-C) and I don't really understand the hopla for these lenses so-called normal. I'd really wish for something a bit wider, a 30mm at the very least.
To get back on topic, there's not much AF lenses under f/2.8 and under 150$ except for the 35mm f/2.4. Photography is really not a cheap hobby...
09-07-2011, 12:31 PM   #33
QuoteOriginally posted by dgaies Quote
There are two Sigma 28/1.8 AF lenses (that I am aware of). The newer one that is currently in production is a lot larger and the cost is subsgtantially higher than $150 (around $350-400 if I'm not mistaken). The older AF Sigma 28/1.8 is smaller and lighter, but is somewhat difficult to find. And again, short of getting a great deal, it will run somewhere in the $225-275 range.
The older version. But yes, not even one in PK that I can see.
QuoteOriginally posted by ManuH Quote
Pentax + (some) manual lenses, yes it is cheap
09-07-2011, 12:36 PM   #34
Bramela's Avatar
QuoteOriginally posted by firefly Quote
There's always the DA 35 f/2.4. Used it should go for just a touch above $150. They're new at $189 now I think.
I've seen used for such price, but I can't seem to find one on the Marketplace now. Or is there anyone here willing to part with this lens?
I would suggest you place a thread in the Marketplace Wanted section of the Forums, that way you have much better chance of reply.
09-07-2011, 12:46 PM   #35
QuoteOriginally posted by Bramela Quote
Adorama list $179 New.
Yes, I will list a thread there
09-07-2011, 07:42 PM   #36
Nick Siebers's Avatar
The Sigma AF 24/2.8 is a nice lens, I used to have one. They're hard to find, and unless you get lucky, they generally sell for closer to $250.
That is what mine cost. It is quite handy!
To the OP, I would caution that AF in dimly lit bars is often slow, not to mention hit-or-miss. So temper your expectations....
09-07-2011, 09:11 PM   #37
RioRico's Avatar
35mm isn't really 'normal' on APS-C. The diagonal of a nominal APS-C sensor is 30mm; on my K20D, it's 28mm. Those are our 'normal' focal lengths. My 35-37mm lenses are "long-normal" or "short-tele", roughly FOV-equivalent to 50-55mm on 135/FF -- and I never really liked that focal length there either, although I was often forced to use it.
That said, I include 35s (and 40s and 45s) in my lens-of-the-day rotation, and force myself to see how they see. That's a good exercise for non-prime users too. Set the zoom to some fixed 'weird' focal length for a week. Leave it there. Zoom with feet. Learn to see different compositions and angles. It's GOOD for you!
Buying new AF zooms sure ain't cheap! That's why I've accumulated so many MF primes.
09-07-2011, 09:56 PM   #38
.. Zoom with feet..
09-08-2011, 01:08 AM   #39
Abbazz's Avatar
Zoom with feet.
No such thing! You cannot replace a zoom with a prime lens and using your feet, because a zoom allows you to change the compostion without affecting the perspective, while moving around with a prime lens does indeed allow you to change the composition but it also affects the perspective. And it's not always possible to move around anyway, like when you're seated in a crowded pub, for example !
Don't misunderstand me, I love prime lenses and use them a lot. But there are times when a zoom lens is the right tool and a prime simply won't make it.
Cheers!
Abbazz
09-08-2011, 05:46 AM   #40
ManuH's Avatar
Zoom with feet.
As our fellow Pentaxian Jens found out, it's not that easy!
09-08-2011, 08:05 AM   #41
RioRico's Avatar
True, zooming with feet is not like zooming with lens.
They result in different perspectives. Which is the point!
(Just keep your filthy feet off of my nice clean lenses.)
Zooming with lens, you get varied compositions at the same perspective.
Zooming with feet, you change both the composition AND the perspective.
Zooming with feet forces you to look more closely at spatial relationships.
Zooming with lens is rather like invading your subject.
Zooming with feet is more like dancing with the subject.
Using my Schneider Betavaron, the subject and I samba.
09-08-2011, 08:16 AM   #42
zooming with your feet works sometimes and sometimes it doesn't.
I can't walk on water. I can't back up thru a cliff. I can't take a picture thru a set of trees. I can't move the foreground that I wanted in the composition. I'm not walking miles across rough terrain when I could just use a telephoto. And the list goes on.
At the same time there are plenty of instances where you find a better or more interesting composition by moving around.
09-08-2011, 08:26 AM   #43
Just1MoreDave's Avatar
I might try two other techniques while waiting for a good deal on something with AF. First, the kit lens can do f4 up to 33mm or so. Just for fun, use that and try raising ISO to the maximum possible value. The noise can add to the atmosphere for that kind of photo.
Another idea: with a manual focus lens, set the focus and aperture for a certain distance and enough DOF so a person at that distance will be mostly in focus. Something like 6 feet or 2 meters away, and 1 foot/300mm of DOF. When something interesting happens within this zone, shoot. Your hit rate will depend on how well you can estimate distance and keep the camera within that distance. It's also a good way to shoot without raising the camera to your eye.
09-08-2011, 09:30 AM   #44
RioRico's Avatar
Ah, now we move from fast lenses to techniques, and why the hell not?!? Yes, bumping-up ISO can give interesting noise-texture effects. I'll use A-type and AF lenses in TAv mode, let the ISO float as far as possible after I've selected the aperture and shutter. Such noise often looks better in B&W with noise-reduction off, than in color with NF on -- the old Tri-X-pushed-to-2000 effect, very dramatic.
And then there's hyperfocus. I'll set a 21/3.8 to f/11, prefocus to 2m, and have DOF from 1m to infinity. Or catch-in-focus -- prefocus any manual lens to a preferred distance, hold down the shutter, and CIF fires when something comes into focus. I use both these techniques with from-the-hip street-shooting. (Or just set the kit 18-55 wide-open and let it autofocus on my unframed targets.) Whatever works...
09-08-2011, 12:17 PM   #45
ISO bumping is a game played mostly by Canonian, I think
K20D is not that good on high ISO, not even as good as my previous K100Ds. I've tried ISO bumping to a point that noise is still acceptable for my eyes, which is at /20 sec. - ISO 800 - F4. Can go to /30 sec - ISO 1600 F4, but only when there is not much shadow or blackness in the frame. But hey, don't we all want better results?
af, k-mount, lens, pentax lens, really-really, slr lens
very cheap k-7 w/ lens jkglogau Pentax Price Watch 102 10-20-2010 02:09 PM
Cheap lens PaladinPete Pentax SLR Lens Discussion 13 04-25-2010 12:34 AM
For Sale - Sold: [US] 2 Cheap ME Supers, 1 Cheap ME - Pentax film bodies Just1MoreDave Sold Items 2 02-21-2010 02:11 PM
Forget the cheap DA normal lens, where's our cheap DA portrait lens? EricT Pentax SLR Lens Discussion 31 10-04-2009 02:01 PM
Cheap manual lens on cheap extension tube with cheap flash! Also cats. pasipasi Post Your Photos! 12 08-28-2008 04:43 PM
All times are GMT -7. The time now is 07:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
