09-07-2011, 05:45 PM   #1
Edgar_in_Indy's Avatar
Need lens hood for Sigma 170-500mm...same as 50-500mm and 150-500mm? Help please!
I just bought a Sigma 170-500mm on eBay, but it doesn't have the lens hood with it. Sigma sells some lens hoods on their site for $25, but they don't list one for the 170-500mm. They do, however, list hoods for two other lenses that take 86mm filters, just like my 170-500mm. Namely, the current 150-500mm OS, and the old 50-500mm non-OS.
My question is, since these three Sigma's all take 86mm filters, is it reasonable to assume that the lens hoods will be interchangeable? If anybody has first hand knowledge, I would really appreciate.
I can always buy a screw-in 86mm hood off eBay for $13, but I'd rather have a bayonet-mount Sigma hood. I also found a bayonet hood for an 86mm Canon EF 70-200mm f/2.8L IS USM on Amazon for $8, but I don't know if Canon's bayonet lens hood mount is different from Sigma's.
Any help would be greatly appreciated!
09-07-2011, 05:47 PM   #2
JinDesu's Avatar
I'd imagine the hood for the 150-500 would be more accurate than the one for 50-500, but only based on the statement I've heard that lens hoods for zoom lenses are oriented around their widest apertures.
09-07-2011, 06:01 PM   #3
QuoteOriginally posted by JinDesu Quote
You're probably right, so if it turns out that both hoods will fit, then I'll get the 150-500 hood. My primary concern though, is whether either of the hoods will fit at all.
09-07-2011, 06:02 PM   #4
JinDesu's Avatar
Oooh, sorry, didn't get that the first go-round. Not sure if they'll fit, hopefully someone else can chime in!
09-07-2011, 06:19 PM   #5
Lowell Goudge's Avatar
Couplenof things to consider, are the lenses all DG. I.e. Full frame, do they have he same attachment size, and are you using it on full frame of ASP-C. If on ASPCA and the lenses are full frame any hood will be I adequate because they are for a wider field of view
09-07-2011, 06:46 PM   #6
I'm actually more concerned with whether the hood will phsyically fit on the end of the lens. Any lens hood will be better than nothing, so I'm not overly concerned at this point about it being the ideal lens hood.
09-07-2011, 07:37 PM   #7
QuoteOriginally posted by Edgar_in_Indy Quote
Keep in mind that a lens hood that is longer than it needs to be has the potential to cause some vignetting at the widest focal lengths.
It's likely that it will attach securely. I have several Sigma lenses, including the EX DG 28mm f/1.8 and the EX DF 28-70mm f/2.8, both of which have a 77mm filter thread, and both of which have nearly identical hoods that can be swapped. If the hoods in question are bayonet, it's likely they'll fit, as I don't think Sigma has changed it's hood bayonet for EX lenses.
That being said, before you order, you might want to try calling Sigma up and asking if they happen to know if it will fit, and asking what their return policy is in case it doesn't.
09-07-2011, 07:53 PM   #8
dadipentak's Avatar
There's always duct tape.
09-07-2011, 08:08 PM   #9
QuoteOriginally posted by nater Quote
With the lens in question starting at 170mm at the WIDE end, I think you'd have a pretty hard time finding a hood that would cause vignetting.
That information is very helpful, thank you. I sent Sigma an email, but haven't heard back from them yet.
09-08-2011, 02:16 AM   #10
darrenleow's Avatar
My 170-500 (APO old school version, not the fancy one with the EX powdery finish) came without a lens hood too, but I bought a screw-in metal hood instead. It's a bit too long to fit into any of the lens cases I currently have with the hood mounted, and removing and installing the hood risks scratching the huge lens front element.
09-09-2011, 05:32 AM   #11
I spoke to someone at Sigma, and she advised that the hoods from the 150-500mm or the non-OS 50-500mm will mount on the 170-500mm. Only problem is that they have the EX finish, so they won't match the smooth finish of the 170-500mm. Not a big deal, but she said she'd check with the parts department to see if they have a hood for the 170-500mm.
170-500mm, bayonet, filters, hood, hood for sigma, hoods, k-mount, lens, lens hood, pentax lens, sigma, slr lens
Sigma 150-500mm versus Sigma 50-500mm? Ubuntu_user Pentax SLR Lens Discussion 6 08-31-2011 09:35 PM
For Sale - Sold: Sigma APO 170-500mm F5-6.3 DG (AF Lens) (CONUS) Pepe Guitarra Sold Items 9 04-24-2011 08:58 PM
Sigma 50-500mm vs 150-500mm or Pentax DA 55-300mm with 1.4 TC? mikejustice Pentax SLR Lens Discussion 20 12-18-2009 07:59 PM
Wanted - Acquired: 100-400mm, 100-500mm, 150-500mm or similar K-mount lens GibbyTheMole Sold Items 8 12-03-2009 11:52 AM
All times are GMT -7. The time now is 04:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
