10-20-2011, 07:27 PM   #76
twitch's Avatar
The FA31 is not an expensive lens at all in the grand scheme of camera lenses. Seriously, anyone thinking it is expensive is clearly not doing enough window shopping at nice camera stores
10-20-2011, 07:39 PM   #77
QuoteOriginally posted by twitch Quote
Well, I suppose that's true. My most expensive lens is an fa 77 so I guess I still haven't passed the $1k barrier. I'm insured for my gear so I shouldn't have concerns about using stuff anyways. You're absolutely right.
10-20-2011, 08:39 PM   #78
paperbag846's Avatar
It's an expensive lens for a hobbiest, generally speaking. If your whole budget is 1000, it would make sense to spread that over a few lenses, rather then blow it all on one (for many people, at least).
Great lens, but if you aren't even going to take full advantage of it, you might be better off with a more affordable alternative.
Why wear a nightgown when dining alone?
10-21-2011, 01:46 AM   #79
kanzlr's Avatar
never start lusting for Leica gear then. Even the f2.8 primes are in the € 1000,-- and above league, even used, sometimes.
10-22-2011, 04:12 AM   #80
FA31 - visible distortion, larger and heavier than 40 mm lens, 58mm filter thread, no focus override in AF mode. Quite sharp even wide open (center), F1.8, mechanical quality is excellent, build in lens hood, would work on full frame camera. I love my 31, but have to admit that it is designed as wide angle lens not as a crop equivalent of a standard prime.
DA 40 - too small, no large aperture. Quite sharp although correction is not superb. Focus override, 49mm filter thread. I have one sitting around. This lens can do nothing special, but works fine for many applications.
Buy the 40 mm and if unhappy sell and compare to the 31 mm. Or vice versa. Or buy both and sell the one you dislike.
10-22-2011, 04:16 AM   #81
B&H will send one to € land for much less.
If price is the only concern, answers become simple. Selling a 31 mm lens used you will loose little of your investment.
31mm, 40mm, da, da 40mm, fa, fa 31mm f1.8, k-mount, lens, pentax, pentax lens, photo, slr lens
Voigtlander Ultron 40mm f/2 vs. Pentax 40mm Ltd (warning: amateur test) dasuhu Pentax SLR Lens Discussion 48 12-05-2013 08:34 AM
FA 31mm limited, FA 43mm limited, 40mm F2.8 Sheridan Pentax SLR Lens Discussion 14 07-28-2010 12:30 PM
For Sale - Sold: Black FA 31mm f1.8 and DA 40mm f2.8 limited lenses (AUS) bonovox Sold Items 0 05-31-2010 12:33 AM
About FR by FA 31mm henryjing Pentax SLR Lens Discussion 5 04-02-2010 12:52 PM
which 40mm? pentax da 40 or Voigtlander Ultron 40mm f/2.0 SL-II dexmus Pentax SLR Lens Discussion 12 10-30-2009 07:26 PM
All times are GMT -7. The time now is 08:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
