09-17-2011, 02:01 PM   #1
Vivitar Series1 F--
Today I pickup a Vivitar Series 1 28--105 1:2.8-3.8 VMC Macro focusing Zoom Made in Japan No.09143820 PK-A/R 67mm at a tag sale for $10.00.
when i put in on the camera pentax K-7 this what came up( 7 - -) in the Manual mode help
09-17-2011, 02:13 PM   #2
Wrong section- moved.
This article contains the answer to your question:
https://www.pentaxforums.com/forums/pentax-lens-articles/110657-how-use-meter...k-x-k-7-a.html
09-17-2011, 06:25 PM   #3
joe.penn's Avatar
QuoteOriginally posted by seaman256 Quote
The best $10.00 you will ever spend! Period! You got yourself a Humdinger my friend! This lens is a fantastic sleeper lens that is capable of 1:2.5 macro (from around 45mm and up) and it produces fantastic IQ and sharpness. FYR, this is a Cosina manufactured lens (the good quality of Cosina, not the bad)...
10-24-2011, 08:14 PM   #4
Remove that Ricoh pin! It's very easy to do on that lens.
10-24-2011, 09:35 PM   #5
Laurentiu Cristofor's Avatar
This is a decent lens optically, but the push-pull mechanism is the worst I've seen:
- short focus throw - just 45 degrees - pretty ridiculous for a manual focus lens
- the movement described by the ring when focusing is a spiral, because the lens extends while focusing
- the zoom throw is short too
Practically, it's impossible to select a focal lens in between 28 and 105 and keep using it - the zoom will creep and because of the spiral rotation, it's not even going to be easy to see what focal length you have ended up using. Mostly, I used it either as a 28 or a 105 - not really what you think when you think "zoom" and disappointing considering that this is a superb focal range.
IQ is ok - it's not very sharp wide open and it's decent stopped down. Good for portraits at long end. Good macro capability at short end. I much prefer the Tamron SP 35-80 - no push-pull, better close up capability at long end.
That being said, for $10 it's a bargain - you can recoup your investment easily and put the money into an even better lens.
01-08-2012, 06:37 PM   #6
royden's Avatar
I picked one up. It's marked Marco Focusing Zoom with a 72mm filter thread. No serial number anywhere???
Did you remove the Ricoh pin? I removed mine and messes up something. I posted on page 7 of the Vivitar series 1 Club. Could you nice folks read it and assist me in getting this lens back to what it once was. I paid $40.00 and it has lens creep. Many thanks.
Ted
01-09-2012, 11:52 PM   #7
QuoteOriginally posted by tkossally Quote
...Did you remove the Ricoh pin? I removed mine and messes up something. I posted on page 7 of the Vivitar series 1 Club. Could you nice folks read it and assist me in getting this lens back to what it once was...
Ted
I would guess that you removed the wrong pin - the Ricoh pin has absolutley nothing to do with operation on a Pentax camera. The Ricoh pin is the one almost diametrically opposed to the red dot.
01-10-2012, 06:42 PM   #8
royden's Avatar
QuoteOriginally posted by m42man Quote
Hey m42man, Removed 2, one at 5 o'clock and one at 6 o'clock. I realized my error and replace the 5 o'clock pin. I did this once before and only removed the problem pin and have no idea why I removed 2 on the Vivitar. Had to be brain freeze.
the only issue left to be resolved is the coupling lever problem. At "A" or small apertures the viewfinder is dark. I may have to use it as a M lens. I replied to calicojack about this too. See Below............ Thanks.
Hello Calicojack,
I pulled apart the lens again and figured out where that small bearing goes and It's clicking again. A small victory. Thanks for your input.. However, one major problem remains. When I move the lever at the back end of the lens I expect the blades to open/close when at small aperture..It dose not. I set another lens that I have at say f22 or 16, move the lever and the blades open and close. I take the Vivitar lens off "A", move the aperture ring through f22 to 2.8 and that works ok. So I may have to use this lens as I would a Pentax M lens. When it is on "A" the view is dark. At 2.8 it's bright and get darker as I stop down. Any Ideas anyone? Thanks
k-mount, pentax lens, slr lens, vivitar, vivitar series1
For Sale - Sold: VIVITAR SERIES1 135MM 2.3 (Worldwide) quartz Sold Items 2 03-01-2011 07:11 PM
Komine Auto Vivitar Telephoto Pre Series1 Konica Mount aliasant Non-Pentax Cameras: Canon, Nikon, etc. 2 02-21-2010 04:40 AM
For Sale - Sold: Vivitar Series1 105mm Macro Foxman Sold Items 11 04-13-2009 02:09 PM
All times are GMT -7. The time now is 10:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
