09-17-2011, 06:12 PM   #1
Steinback's Avatar
Anybody know off hand how to remove the focusing ring on an A 50mm f/2.8 macro?
I've worked on a couple of M series primes and normally the trim ring on the front unscrews fairly easily to expose the screws underneath. I don't seem to be getting anywhere with the A 50mm f/2.8 macro - I want to remove and rotate the focus ring by about 90 degrees so that infinity is indicated at the right spot on the distance scale. A previous repairman must not have been paying enough attention during reassembly.
09-17-2011, 06:52 PM   #2
Giveaway winner!
MysteryOnion's Avatar
Does you lens have a narrow textured ring along the filter thread? Just wondering if that is like my A series zoom. On my lens it can simply be gently slipped off with a very small hook tool.
09-17-2011, 07:18 PM   #3
Steinback's Avatar
The focusing ring is separate from the filter threads and the filter threads move with a non-rotating lens group inside the focus ring. I'll see if I can get the rubber grip to lift up at all at the edges.
SMC Pentax-A 50mm F2.8 Macro Lens Photo - Pentax Lens Reviews & Lens Database
I sort of expected the trim ring with the lens name on it to just unscrew and reveal screws holding the focus ring underneath (and it may yet, with enough force).
09-17-2011, 07:33 PM   #4
Giveaway winner!
Given the long helix/helicoid of the lens, I would wonder if I should suggest the rubber grip comes off to reveal set screws? I would hope someone chimes in and knows this answer as I have M series lenses and only two A series. On the zoom...
you see a notch and the trim piece spins freely with enough give to lift out, but I would slightly heat it under the warmth of a lamp as it looks like cheap brittle plastic.
50mm, f/2.8, k-mount, pentax lens, slr lens
D FA Macro 50mm focus ring travel bwDraco Pentax SLR Lens Discussion 3 01-15-2011 08:17 PM
How to remove focusing ring on K50? axl Pentax SLR Lens Discussion 1 09-28-2010 02:36 PM
HELP! Can't remove T ring adapter wildman Pentax DSLR Discussion 4 05-24-2010 07:37 AM
Can I remove the "A" position lock on my aperture ring MikesChevelle Troubleshooting and Beginner Help 17 02-13-2010 02:52 PM
For Sale - Sold: 50mm Lens and Macro Focusing Teleconverter Youngster Sold Items 4 09-29-2009 07:00 AM
All times are GMT -7. The time now is 04:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
