09-21-2011, 04:29 PM   #16
Yes, the spring goes *inside* the A pin, so you can probably imagine how tiny it is (I'd guesstimate no more than 1mm diameter, maybe even half that). I've worked on a lot of electronics and electro-mechanical stuff in my life, but have never seen a spring this small. It's like watch-spring small, and I have zero experience with watches. I can try re-assembling it without the pin to see what happens. Honestly, it couldn't be any worse.
09-21-2011, 04:53 PM   #17
QuoteOriginally posted by wedge Quote
I'm thinking it will function normally with the exception of not having the A setting. You can use it that way in the meantime till you can find a spring. Did you ever find any indication of why the A setting was not working reliably?
While I wouldn't buy one for this reason, should you ever wind up with a junk lens, try the aperture detent ball spring. If I can think of any good source I'll post. There is the option of a film camera body too.
If you live in a bigger town you might want to see if any local gunsmiths could hook you up. Likewise, maybe a watch repair shop. micro tools or online watch repair or gunsmithing supply places might be a place to look.
09-21-2011, 05:13 PM   #18
How about the spring out of a watch bar cut and ground down (like the bar that goes through the band). That should be cheap enough if it's small enough? A whole box of them is 4$
Set 340 Stainless Steel Watch Spring Bars Pins 1.5mm | eBay
though I might look locally first so you know how big they are?
09-21-2011, 05:33 PM   #19
If you don't wind up finding anything, pm me. I'm not making any promises but I may have something if you are not in a hurry.
09-21-2011, 07:51 PM   #20
I've got a box of old film cameras (cheap 35mm dial-wind types) that I can scavenge parts from...I hadn't thought of that possibility. And I didn't find any clear reason for the A setting not working. There was some dirt in there on the electrical contacts, so that could have been causing the intermittent behavior.
bodies, contacts, k-mount, lens, pentax lens, slr lens, smc-a
Do custom "artistic" or even "funny" lens caps evenexist? lovemehate Pentax SLR Lens Discussion 35 02-10-2016 09:10 AM
For Sale - Sold: Nice SMC "K" 55mm f/1.8 lens Nick Siebers Sold Items 6 05-06-2011 06:57 AM
"smc PENTAX-DA" badge and the DA 18-135mm lens bwDraco Pentax SLR Lens Discussion 3 02-28-2011 10:43 PM
K-mount Experts: How to convert a "KAF2" lens to "KF"? panoguy Pentax SLR Lens Discussion 24 07-08-2010 05:20 PM
SMC Pentax-M 40mm F2.8 "pancake" lens luckinpentax Pentax SLR Lens Discussion 18 12-16-2009 10:21 AM
All times are GMT -7. The time now is 03:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
