Cant help you with comparison as I don't have the 14mm.
I can give you the maths though. Hope I haven't c*cked it up?!
If the subject is 1000 (units, mm, inches. whatever) from the focus plane than the image plane size would be:
14mm gives 1648 x 1099 units.
15mm gives 1537 x 1024 units (this is 6.7% smaller in linear dimension, or 13.1% smaller image area.
Now if you have the 15mm on and you move futher from the subject by 67 (units) then i guess you will have the same view as the 14mm lens.
Really I guess the main difference is the whole extra stop of light available to the 14mm.
