Originally posted by RonHendriks1966 Personally I think I can't make such a picture with a long shuttertime like that at all.
just don't drink coffee
it is all a question of being relaxed, I will have to admit this is as far as I can push the envelope, and the point has been discussed many many times on the forum, it is all about technique.
I would agree that SR has made the image possible, but all SR did was correct for the parts of my technique i did not have control of at the time.
SR or OS is a good tool, and in many instances can help someone with bad technique to get an image that would not otherwise be possible, but it really rewards someone with good technique to start with. In my opinion if you have good technique, IS is better only because you only purchase it once (with each body)
As I said earlier however, I can also see where OS may help on focus accuracy, because the image presented to the focus detector is stable. Vertical shake especially can cause huge focus errors at a distance with a tele lens because you move from foreground to subject to background for example as the lens shakes up and down.
