09-25-2011, 11:04 PM - 1 Like   #1
Arrvon's Avatar
Magnification Tests: Raynox 150 w/Tamron 18-250mm and Pentax 100mm Macro
Hi all,
Just figured this would be of good reference material for anyone thinking of picking up a Raynox DCR150 to see how the magnification increases on these two lenses. I did the same 'test' with the Tamron 70-300mm back when I had that lens and decided I would do the same with the two lenses I have now.
I was surprised to see that the 70-300mm was able to magnify much more than the dedicated 100mm Macro was, but I guess that's just a factor of the extra 200mm focal length at play there.
If you would like to compare these results with those of the Tamron 70-300mm, check out the pics on the old thread here.
Hope some people find the comparisons useful. Without a doubt, I would easily recommend the Raynox DCR150 to anyone. It is well worth the $50 or so!
09-25-2011, 11:11 PM   #2
Thanks for your samples. I have my eye on the Raynox 150 and possibly the 250 as well. The 150 should be fun with my SMC-M 100mm/F2.8 and the DA 50-300mm.
09-26-2011, 01:51 AM   #3
RioRico's Avatar
QuoteOriginally posted by Catalana Quote
You may or may not know that the DCR-150 is +4.8 dioptres and the DCR-250 is +8dpt. They have the same magnification as some cheap +dioptre closeup adapters stacked to give the same +dioptre number; but the Raynoxi are corrected, and much better optically.
If you get a DCR-150, you can stack 49mm adapters on it; a +1+2dpt pair stacked on it give almost the same magnification at a DCR-250, so you could get an idea of whether buying the -250 makes sense. The main difference (besides magnification) is working distance. WD for the -150 is about 6in-7.5in; for the -250 is about 5in.
09-27-2011, 05:15 PM   #4
Thanks for making the differences more clear. I was just checking the prices for the Raynox, and it seems that they have increased by some ~50%. I thought this a bit steep and have decided to just wait and get a proper macro, i.e. the Pentax 100mm or Tamron 90mm. Bad experiences with Sigma and their service put them out of consideration.
09-27-2011, 05:52 PM   #5
RioRico's Avatar
Here's the formula for finding magnification with closeup adapters:
[ M = F * D / 1000 ]
where M is magnification, F is host lens focal length, and D is dioptre of the add-on lens.
So putting a Raynox DCR-250 (+8dpt) on a DA55-300, we get numbers like this:
at 55mm: 55*8/1000 = 0.44x
at 135mm: 135*8/1000 = 1.08x
at 300mm: 300*8/1000 = 2.4x
Anyone with a calculator can plug in the numbers for other lenses and adapters.
____________________________________________________________________
As for Raynox prices: I search eBay and see both the DCR-150 and -250 going for less than US$60 each, shipped. The IQ of either is much better than with stacked closeup mensicus sets, which (for larger diameter lenses) are not astoundingly cheaper. Yes, a dedicated macro lens will be cleaner, but will cost rather more. It will probably weigh a bit more too. Yes, I adore my M42 Vivitar-Komine 90/2.8 macro (480g). But I always have my DCR-250 in my bag, and I'm more likely to clip it onto my Isco Westar 100/4.5 (170+70= 240g), half the weight.
My recommendations:
If IQ is paramount and money isn't tight, get a dedicated AF macro lens.
If IQ is paramount and money IS tight, use macro tubes.
If IQ and convenience are important, use a Raynox.
If IQ is less important, use cheap closeup lenses.
100mm, 70-300mm, dcr150, k-mount, lenses, macro, magnification, pentax lens, raynox, slr lens, tamron
Raynox 150/250 with PENTAX 645? caretatra Pentax Medium Format 8 10-16-2012 04:35 AM
how to calculate the Raynox magnification rate? clockwork247 Pentax SLR Lens Discussion 22 09-25-2011 02:18 PM
Raynox 150 not giving me better macro :( SirJangly Pentax SLR Lens Discussion 10 09-24-2010 10:56 AM
Magnification Question: Reversed 50mm vs. Raynox 250 twokatmew Troubleshooting and Beginner Help 2 07-18-2010 04:15 PM
Magnification test: Raynox 150 w/ Tamron 70-300mm Arrvon Pentax SLR Lens Discussion 0 10-24-2009 03:54 PM
All times are GMT -7. The time now is 06:19 PM. | See also: NikonForums.com, part of our network of photo forums!
