Originally posted by catastrophe Also, will it be bad to use a CPL on a wide angle such as the 15mm?
Funnily I just got a Hoya ND 0.9 filter and I have a Marumi CPL
The Hoya did not come yet but I chose it because it's multicoated (HMC). Try to get a multicoated for any filter you buy otherwise be prepared to endure bad flares. The Marumi DHG super CPL is thought to be one of the best CPL filters (by Lenstip.com, see their polarizers tests).
Using a CPL on the 15mm is possible, I do it at times, just be careful with the skies as the color can be uneven.
EDIT: Oh yes I forgot, for the ND400 I chose the B+W ND 3.0 10 stops filter. There is a multicoated version (70$) and a single coated (56$) at B&H. Not much issue with it apart from the expected color cast (warm in this case).
