Hi TheWengler
I imagine it's technically
possible that if you 'stacked' a 62mm polarizing filter in front of a 62mm UV/Skylight filter, you might experience some slight vignetting at the extreme 18mm wide-end of Pentax/Tamron's 18-250mm Di II superzoom.
However, there are two easy solutions to avoid this pitfall:
a) unless you enjoy seeing undesirable internal reflections in your images, temporarily remove & store the UV/Skylight filter, replacing it with the polarizing filter as and when required
or
b) purchase a 62-72mm step-up-ring and add a 72mm polarizing filter. Bear in mind however that the large diameter polarizing filters can be incredibly expensive nowadays, unless you can get hold of a decent secondhand one.
I would probably select option b) in order to avoid the irritating and time-consuming requirement of post-processing affected images. You may not be aware that vignetting can easily be removed in most of today's photo-editing software packages !
Best regards
Richard
