Yeah, I know, don't put a cheap CPL on the front of a good lens. But when the lens is a $150 lens and has the somewhat odd size of 72mm and which I'd like to think I will upgrade some day, it doesn't make sense (nor cents at this time) to me to spend close to a $100 for a great CPL. Beside cost, bottom line for me is that, from my experience, a little loss of sharpness using a CPL is better than the glare and loss of contrast when not using one.
So, I'm looking at cheaper CPLs, and I'm hoping for some advice/experience. I've already eliminated all the usual suspect brands and am looking at 3 possibilities:
Vivitar and Kenko are under $20, Marumi at ~$40. I'm guessing that the Kenko and Marumi are better quality, but only the Vivitar is multi-coated. Any opinions or other suggestions will be appreciated!
