Hi,
a big thanks to all of you for your replies, here come the answers.
icywindow : no i didnt use the hoods, the overhead bright spot was a sun ray shining off cd's onto the wall.
hcc & jin: good question, i did not disable the SR nor did i know you had to switch it off when you use a tripod : why is that? The cropped images are only crops, no resize so if you maximize them you'll have 100% zoom. I've also uped the original jpegs on photobucket as mentioned in the original post.
calsan : totally agree, the problem is the light/air has been this way for at least 10 days, today it is even worst...i guess it's the heatwave going on through Spain causing a lot of land/moisture evaporation. Seeing as i dont have a polarizer i can't do anything about it.
Special & arv : thanks for input, concerning the focus plane the 17 70 is hard to adjust in order to get to exactly 30mm as the value isnt printed on the lens barrel : only 24 and 35, in between it's all a guess, the K7 isn't precise enough to give me the exact focal lenght : either 28 or 31mm...
bdery : thanks, it really is beautiful & magic here in Granada...great cheap friendly beautiful place to chill out for a few months...a good get away from the big cities...beaches & ski slopes both only 45 minutes away...
shared flats starting at 120-140€/month for a room...
Thanks for your feedback, i definately do not want to start peeping, i know exactly what you mean.
Anyway in order to be sure I just took 2 more inside pics with each lens, scene about 2,5m away, the first one in AF and second in MF (used the camera's focus confirmation viewfinder flash & sound beep in MF). All are shot using A mode, no hood, SR off
(jin is right, 2s timer switches it off automatically) ; . I've uped the four pics there, look at the file name for description :
Lens Tests - Raw jpegs pictures by s0lspot - Photobucket
Aperture was 5.6, Auto speed : 1/6 for the 30mm and 1/8 for the 17-70mm (don't know why the camera chose to slow it down for the brighter 1.4 30mm?) and 200 iso.
Please check those out, let me know your gut feeling and that will be it with these questionings...
Thanks a lot in advance to all the community!
