10-04-2011, 07:34 PM   #1
Lens hood for 77mm Limited?
Does anyone use a longer lens hood on their 77mm when they use it with their DSLR?
For my 31mm I bought a 58 to 55mm step-down ring and a 20mm long metal hood based on a thread on DPReview. It works great and provide extra protection for the front element for those of us who don't like use filters.
Do people do the same for the 77mm?
(In case it's not obvious, the built-in lens hood is optimized for use on film cameras, so a longer one would shade better for cropped DSLRs.)
Thanks - Greg
10-04-2011, 08:28 PM   #2
frank's Avatar
Yes, I use longer hoods on all three FA limiteds:
10-04-2011, 08:34 PM   #3
Are those any specific brand? Or just generic ebay ones?
How long is the 77mm one and what's the diameter at the lens cap end?
Thanks - Greg
10-04-2011, 09:14 PM   #4
frank's Avatar
QuoteOriginally posted by greg_77 Quote
Thanks - Greg
The hoods on 43 and 77 are the same w/ 49mm screw-on thread so you can use them on any normal to mid-tele lens w/ 49mm filter thread size. The hood has a 58mm front thread for a clip-on cap, much easier to use than those w/o front thread. FA31 is a bit special, you can't use a hood like this w/o an extension ring or step-down ring. Lucky I found a 58mm straight hood (more like a filter extension tube) made by Heliopan, it works perfectly on a FA31 when mounted on a cropped dSLR camera, but it'd couse dark corners when used on a film camera.
10-04-2011, 09:22 PM   #5
QuoteOriginally posted by frank Quote
Thanks frank.
I wonder how well this ebay link one would work on the 77. It's 36mm long. I don't have my 77 lens yet so I don't know how that compares to the built in hood.
Greg
10-04-2011, 10:23 PM   #6
wlachan's Avatar
Any tele hood will work. The only concern is that generic hoods being made in China or Inida are often poor quality. The thread will scar your lens. But if that doesn't bother you, then they can be had for a few bucks only.
Mine is the B+W 960 which is not cheap, but the original cap fits right on, not that I have found useful.
10-04-2011, 10:28 PM   #7
QuoteOriginally posted by wlachan Quote
Understood. For my 31mm I bought a Tiffen (Made in USA) step-down ring rather than a generic, so no cheap threads touch my new Limited lens.
Greg
10-04-2011, 11:34 PM   #8
axl
Quite a few folks are using Heliopan straight hoods for FA ltds.
Another option (the one I took for all my hoodless SMC primes in my MF days) is to get 49-52 step up ring and then metal clip on Nikon hoods from their old MF primes. There is a hood for Nikkor 105/2.8 and 135/3.5 that I used on my M85/2. I'm sure it would work great on 77ltd. If you leave the step up ring threaded in on the lens then you can even turn the hood bacwards for storage.
My 2p
10-05-2011, 06:39 PM   #9
Thanks to the comments in this thread I remembered that I have Takumar metal hood (for 135/3.5, 150/4 and 200/5.6) that I use on my 50mm (D'oh!). It should work just fine on my 77 so I guess I don't need to buy anything.
Just for future reference of anyone finding this thread: the Takumar hood is 51mm long (not counting threads) and the diameter is 60mm. For comparison the 77's hood extends 14mm and is 52mm diameter.
Greg
10-06-2011, 01:15 PM   #10
I have used an inexpensive metal hood from heavystar on eBay with my FA 77. It is his "tele" model in 49mm.
10-06-2011, 06:52 PM   #11
steve1307's Avatar
Here a link to the one Steve is talking about.
New Metal Tele 49mm Screw-in Lens Hood + Cap | eBay
I bought the 58mm "standard" version for my 55/1.2 because it reeaally needs it when shooting outdoors.
I'm just wondering whether I could have bought the "tele" version instead since I'm only using on APS-C.
Anyone know of any links to hood design calculations?
Really, it might be easier just to buy it for $10 and test it out for any vignette.
Maybe I guess if its suitable for 85mm full frame then it'll be OK.
Edit
Searching.......
Well here we go then: https://www.pentaxforums.com/forums/attachments/pentax-slr-lens-discussion/46...d-hoodcalc-zip
oh it appears there's more to it than a simple calc
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/134700-optimum...alculator.html
10-06-2011, 08:14 PM   #12
TOUGEFC's Avatar
I use the standard hoods on my FA LTD's and have never ran into a problem regarding flare outdoors.
10-07-2011, 05:50 AM   #13
Lowell Goudge's Avatar
I think what a lot of people fail to realize, is that many lenses use hoods that are shorter than what is optimum. The migration to digital only makes this worse.
There was, several years ago a spreadsheet out there on the web called Hoodcalc, which could be used to determine the length of the hood based on the sensor format (and more importantly the diagonal)
while the spreadsheet is not without issues, iuf you understand a few reference points it is very useful.
I uploaded a copy on the forum at one time
as a simple note, I usually move one focal length or more down, with my Tak's and the hoods. I use the hood from my 50/1.4 on the 35/2 for example, and the hood from my 200/4 on the 85/1.9
neither change causes vignetting.
10-08-2011, 01:08 AM   #14
Here's a photo of my new 77 with the Takumar 135/3.5 tele hood. Makes it look pretty big.
77mm, hood, k-mount, lens, lens hood, pentax lens, slr lens
For Sale - Sold: Pentax SMC-FA 77mm f/1.8 Limited black AIV w/B+W hood (Worldwide) wrjacobs Sold Items 5 07-12-2011 11:34 AM
where to find PH-RBK 77mm lens hood for da*200mm or 300mm suzuki-j Pentax SLR Lens Discussion 4 03-03-2011 07:48 PM
Lens hood for FA limited? LFLee Pentax SLR Lens Discussion 11 12-04-2010 02:24 PM
Wanted - Acquired: PH-RBJ 77mm DA*16-50mm Lens Hood maximm Sold Items 2 01-10-2010 10:56 PM
For Sale - Sold: Like New Pentax-FA 77mm Limited lens 65535 Sold Items 14 11-19-2009 07:52 PM
All times are GMT -7. The time now is 09:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
