Originally posted by ron2352 I was told for starting out with a new K5. For the type of photography I do. The 60mm-250mm is a good choice for telephoto and the 16mm-50mm would be good for wide angle. I am pretty much sold on the 16mm- 50mm. But would the 60mm-250mm be a good lens for wild life and photographing top fuel dragsters and funny cars? With an occasional air show? Also planning a trip to Costa Rica and the Phillippines. So will be doing a lot of parrots and wild life there. Plus going to tour Corrigador and other places in the P.I. If this sounds basic Iam still a novice.
I've owned the 16-50 since they first came out. It's my walking around lense
and has much to be said in favor of it. It took some getting use to, but
I wouldn't be without it.
Except for Macro, and long shots, it's what I use even though I have a box
of other lenses.
On the long side, life is full of compromises. Your choice is a good one in the abstract, but nothing is perfect. If the lighting is bad, a real fast prime
is to be preferred. If it's real small and a long ways off, long lenses are never too long unless the lighting is bad, and then maybe speed is more important
than focal length.
You gotta pick your medicine go wih it, but your choice is reasonable. I own
the 60-250 --- and its good from a quality standpoint.
