Originally posted by tomwil
One other question that hopefully someone can answer ... is the field of view the same at 200mm for both the 18-200mm and the 28-200mm?? Or, does the crop factor (x1.5) of the 28-200mm actually make it a 300mm view?
Think of it this way. You have your lens at 28mm and point it at a car. The whole car fills the frame. You zoom to 200mm and only get the wheel. you are getting a smaller image and the longer focal length.
Ok so you have a full frame lens and a full frame camera. At 28mm, the car fills the frame. The lens is putting through the image of the whole car. The full frame sensor captures the image of the whole car. You use that full frame lens on a apsc sensor that is smaller. The sensor only captures a smaller image out of the center of the full frame image that the lens is putting through. It doesn't capture the whole car. Its a smaller image compared to what the full frame sensor captured. The smaller sensor is only capturing what the full frame sensor would at 133mm. The only time there is a difference is when you are comparing what a full frame sensor camera will capture compared to a smaller sensor camera.
Ok so you have the full frame lens on an apsc camera, and it is only taking part of the image out of the center. The extra image the lens sends through around the edge is unused/wasted. You are getting part of the car. With a lens designed for apsc like the 18-200mm, you are removing that unused glass making the glass smaller, basically removing the glass that was unused anyway so it has no effect. 200mm is 200mm.
Here is another way of looking at it. You have a 60x magnification telescope. Lets say the glass on the eye piece is 1/2". You see a particular size image. You then take a piece of paper that has a 1/3 inch hole in it and place it over the eye piece. You are seeing a smaller image as if you had more magnification, but you don't have more magnification. The telescope is still 60x, you are just looking at a smaller portion of what the telescope is putting through so you see a smaller image. That extra image the telescope is putting through, that is being blocked by the 1/3" hole in the paper is being wasted/blocked. The 1/2" eye piece telescope is like a full frame lens, and putting the 1/3" hole paper over it is like using a crop sensor camera. You then take a telescope that is 60x but has smaller diameter glass. The eye piece is only 1/3" to start with. It is still 60x so you get the same magnification. If the telescope is 60x, it is 60 x. If the lens is 200mm (the magnification), it is 200mm. You see the same image on the larger telescope with the 1/3" hole paper, as you see with the smaller telescope with a native 1/3" hole. They are both 60x magnification.
Does that make any sense?
