10-10-2011, 02:53 PM   #1
You want 8800mm with Pentax glass?
Get a Q
The planet Jupiter
Pentax Q+smc Pentax M*800mm f6.7 ED+2X Rear Converter
From Flickr: nkenji's Photostream
10-10-2011, 02:55 PM   #2
aurele's Avatar
ask clinton and his A*12000 f8, maybe you can get something closer of this Jupiter
(i'd love to see this setup : A*1200 and Q)
10-10-2011, 02:59 PM   #3
Ex Finn.'s Avatar
I take it that that is not a crop?,
10-10-2011, 03:02 PM   #4
Ex Finn.'s Avatar
Is that a 100% crop?.
10-10-2011, 03:05 PM   #5
I don't think that is a crop.
Atmospheric conditions etc make for the haze I expect. Urban Japan probably isn't the best place to do astro-photography.
10-10-2011, 05:07 PM   #6
Ex Finn.'s Avatar
I did not think so, scary magnification and looks good.
10-10-2011, 07:11 PM - 1 Like   #7
steve1307's Avatar
QuoteOriginally posted by Ex Finn. Quote
could probably work it out?
The posted image "original" on flickr is 2048 x 1536 pixels and by scaling the subject it measures about 230 pixels across.
The orignal might be resized or cropped from 4000 x 3000
FL is what?? 800mm x 2 = 1600mm
sensor is 6.17 x 4.55 mm
The diameter of Jupiter is about 140,000 km.
So, if its just resized the frame is about 1.2467 million km x 934,956 km.
Calculating the distance that works out to 329 million km which is a bit close.
If its a 2048x1536 crop from the original 4000x3000 then the full sensor image would cover
2.4348 million km x 1.8261 million km
Now the subject distance calculates out to about 642 million km. (kind of about right)
Its should be between 588 and 968 million km from Earth but how far away was it last Tuesday night?
Anyone got NASA's number?
So assuming I havent cocked up the numbers (quite probable) it looks like it is a bit of a crop to half size from 4000x3000 to 2048x1536.
Pretty impressive for "a toy camera" as some people refer to it.
I wonder how thin the DOF is out there.?
10-10-2011, 07:20 PM   #8
v5planet's Avatar
I have also photographed Jupiter with a Pentax camera. It was with my K-7, attached to a 2000mm Schmidt-Cassegrain telescope. I can assure you this outdoes my effort.
jupiter
There are advantages to small sensors.
10-10-2011, 07:28 PM   #9
You just blew my mind.
10-10-2011, 07:29 PM   #10
v5planet's Avatar
Incidentally, according to Sky & Telescope's Jupiter Javascript utility, Jupiter is currently approximately 4 astronomical units from the earth.
That is roughly 600 million kilometers. I'm going to agree with steve's analysis that this is an approximately 50% crop of the original image.
edit: http://www.skyandtelescope.com/observing/objects/planets/3307071.html?page=2&c=y#
10-10-2011, 07:44 PM   #11
steve1307's Avatar
Yeah I looked it up here Solar System Live
and its about 600million km away at the moment. 1 AU = 149,597,871 km
so Jupiter is currently 4.012 AU away = 600 million km which looking at the diagram is pretty much as close as they get.
My calc of 642mil km is a bit out because I was scaling the pixels from the fuzzy edges and was only guessing the crop h might have done.
10-10-2011, 07:52 PM   #12
v5planet's Avatar
QuoteOriginally posted by steve1307 Quote
Yeah, given the clarity of the cloud belts out almost to the edges of Jupiter's disc, I couldn't think that the fuzzy edges would add more than about 25% error.
10-10-2011, 07:59 PM   #13
I think a video of Jupiter and it's satellites would have been groovy. Or a time-lapse - the Q has some sort of time lapse utility built-in, apparently.
This is the basic rig I think nkenji used for the shot, with the addition of a 2X convertor:
using 3 adapter
Q to C, C to N, N to 67
4400mm (forcal length in 35mm)
This is another of his setups - a handy 990mm walkabout :
Pentax Q with Voigtlander 180mm f4
(990mm focal length in 35mm)
10-10-2011, 08:07 PM   #14
Really makes me wish I had a Q-K adapter or go out and buy the Q-C and C-K adapter right now. I have a 650mm (3600mm equivalent after crop factor) telescope with an equatorial mount that also has a motor to keep the image centered on the subject. Perfect for astrophotography and doing time-lapse movies.
I think this is the power of the ILC cameras and the Q's smaller sensor size.
10-10-2011, 08:37 PM   #15
QuoteOriginally posted by LowVoltage Quote
Agreed! I think I will give up now on astrophotography with my K-x...
flickr, k-mount, pentax, pentax lens, slr lens
Older Pentax Glass Kim C Pentax SLR Lens Discussion 4 05-16-2011 06:13 PM
Minolta glass vs Pentax? axl Pentax SLR Lens Discussion 9 02-11-2010 02:05 PM
old Pentax glass superior to new??? kiwao Pentax SLR Lens Discussion 37 01-06-2010 06:13 PM
Question re using K200D, Kx, K7 w/Pentax M glass atown Pentax DSLR Discussion 7 11-01-2009 03:57 PM
Autumn colors - old glass is a good glass andrei46 Post Your Photos! 5 10-26-2007 09:35 AM
All times are GMT -7. The time now is 10:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
