Originally posted by Penta_Prisma thanks Lowell for your reply.
I appreciate your advice and agree with you.
still prefer only one lens to start with, with big focal range.
Budget : 700 euro
please if possible come with brand and model name.
thanks
i don't know which lenses are compatible , Sigma? Tamron ? which one of those around 700 euro is considered the best option ?
looking for something like 18-200 and similar
six
just a few comments about a super zoom (big focal range) as you put it.
These lenses have a lot of compromises, which may lead you to quickly look for alternatives. They are slower and not as sharp as the more conservative designs of a 3:1 zoom ratio lens, and this is especially true for the transition from wide to tele.
Also, these lenses generally "suffer" from another behavior, (I say suffer but perhaps exhibit is a better word), specifically, at other than infinity focus, the focal length is reduced as you get closer. This is a characteristic of internally focused elements.
this has been discussed on the forum. In reality it should not be too much of an issue except when you want to really zoom in on something both relitively small and relitively close.
One additional thing, and everyone will have a different perspective on this (pun intended) As I shoot more, I often find myself taking only lenses below 85mm or above 85mm. If I am out doing wild life I go long, if I am city bound I go wide. My last several trips to europe for example I took a range from of lenses 10-85mm and nothing longer.
Since you will be adding lenses later, and no super zoom goes below 18mm, why carry all the additional weight of a super zoom over an more reasonable 18-70 for example. If you are going to spend $700 on something, that would be my recommendation.
