Originally posted by RioRico Yes, a 50mm EL on a bellows extended to ~150mm gives magnification of about 2:1. Yes, working real close pretty much demands a tripod or other immobilization, and maybe focusing rails, and practice practice practice. This is not a pastime for the impatient. But macro shooters are supposedly the happiest photographers. Have fun! Get happy!
I've owned and used both 50 and 100 mm manual and auto focus Pentax macro lenses over a good number of years. I have bellows, extension tubes, and lens reversing rings, and alas, a pentax ring flash.
I have disposed of all of my Pentax-A and older lenses. And it has nothing to do with optical quality, which I regarded as just as good.
the Pentax-F and later macros are F2.8 in speed and have a longer throw. I find both invaluable. While the depth of field is so little
that you would rarelyl want to take a photo at F/2.8, it gives you a really sharp focus point which is what you need. While I suppose exactly what you do depends on how you want to manage the brokeh, but I usually like to black out the background which sort of comes natural
if you use a ring flash with around an f16 or smaller aperature.
I find the Exif quite valuable, particularly if you also record the GPS data on macro work if you are doing it in the field, because other wise
you can never find your way back to what you did. This drives me to want a Pentax F and later lens and irritates me that I can't use both the
O-GPS1 and the ring flash at the same time.
I"ve been both ways on the 50 vs 100 mm length. when I had the old ring flash-- the afc080 I used the 50mm because it was short on power
to work at the distances required for the 100mm. Now I have the AFC160, and it has a minimum distance in which it will work which is more consistent with the 100mm lens.
