IFF
.1) You don't mind shooting only macro, AND
.2) The MD lenses isn't too long+heavy, AND
.3) You don't mind mucking-up the lens a bit,
THEN
Here is a cheap solution. Get some ultra-cheap PK macro tube sets. Save the tubes; just use the PK mount sections. Epoxy the female section around the MD bayonet. (If it's a lightweight lens you don't wish to permanently alter, use contact cement, which dissolves in acetone.) Let it dry thoroughly. Now screw-in the male section, and voila! Note: Some lenses, like the MD Kiron-made 85-210/4.5 in my hands now, have a small tab that prevent the mount section from sitting flush. Either breat off the tab, or dremel a spot in the mount for it.
